587,272 active members*
4,688 visitors online*
Results 1 to 5 of 5
    Apr 2024
    4
    Question Sinumerik 810T TRANSMIT G131 Emco 342
    Hey, Sorry for my bad English. So the patient is SINUMERIK 810T and Emco Turn 342.I need to use the TRANSMIT function to mill a contour on a C-axis lathe. Previously, this option apparently worked before the PLC crashed.Below are the machine data that I currently have entered in the machine tool.Generally, when trying to execute the program, the program starts but stops at block N170 with error no. 2043 1 N170 progr.Error on transform.The question is what is missing that won't start?
    MD 5061 1111 0001 (G131)
    MD 5062 0001 0000 (X1)
    MD 5063 0001 0001 (Y1)
    MD 5064 0000 0010 (Z)
    MD 5065 0000 0000 (X)
    MD 5066 0000 0101 (C)
    MD 5680 0000 0000 (X)
    MD 5681 0000 0010 (Z)
    MD 5682 0000 0101 (C)
    MD 5683 -----------------
    MD 5684 -----------------
    MD 5685 0001 0000 (X1)
    MD 5686 0001 0001 (Y1)
    Below is a fragment of the program that I want to run from the machine tool manual
    May 2024
    Re: Sinumerik 810T TRANSMIT G131 Emco 342
    Hello. I have an Emco ET 345, ´98, 810T GA3. C axis (0,001) and positioning devices (3°). I've tried transmit, but I can't get through the G131. Alarm 2189 - Transformation undefined.
    I'm not sure if I have this option. But the parameters were set like yours, so I assume so. Do you have "tool type" = 30 and inverted corrections?
    Do you have the sinumerik code B65 for the option on the label? I don't have :-(
    Sorry for my English
    Petr S.
    Apr 2024
    4
    Quote Originally Posted by PeSturn View Post
    Petr S.
    Hi, I have "tool type" = 30 and inverted corrections.
    I don't know if I have entry code B65. I see the previous owner programmed the y-axis
    May 2024
    Have you tried a simpler shape with no radius? Just the straight line G1.
    Another note from the manual: The adjustable angle of rotation for coordinate system rotation (G54-G57), (G58,G59) must be zero.
    The B65 code should probably be on the nameplate on the system case.
    Apr 2024
    4
    I have tried all options. Only with G1 and with radii G2 and G3. Still the same error.
    The question is what is hidden under the code B65. Some kind of expansion card or maybe an added cycle?
  1. Replies: 13
    Last Post: 04-12-2024, 10:15 AM
  2. EMCO 460 (Sinumerik 810T)
    By kickinger in forum GibbsCAM
    Last Post: 07-16-2016, 06:23 AM
  3. Replies: 3
    Last Post: 01-12-2011, 05:53 PM
