548,315 active members*
2,472 visitors online*
IndustryArena Forum > CNC Electronics > General CNC Machine Related Electronics > skipping steps with old and new control board.
Results 1 to 6 of 6
    Feb 2015
    10
    Hi, i have a little desktop cnc. It has nema 17 motors (2.1 oms on both wire pairs) cheap 3 axis grbl controller no limits with ugs running it and all axis move very nice and smooth. It is skipping steps when running a gcode file like it has 0 power but when I jog it even with speed and acceleration high it has a lot of power even if i push on it when moving, the holding power is really high also. $1 is set to 255 so it is holding. I have set the driver current to 690mv, I got a new control board and tried that... no change, done every youtube setup tutorial, and I shielded my spindle wires. The motors and drivers are not much above room temp.
    Feb 2015
    10
    Re: skipping steps with old and new control board.
    I have also tryed several different power supplies.
    Apr 2004
    5419
    Have you tried lowering the acceleration on the axes that are faulting?
    Andrew Werby
    Website
    Feb 2015
    10
    yes I have gone slower and faster in case it was resonance. In both acceleration and top speed.
    Jan 2018
    1016
    If they're only room temp can you up the current settings on drivers?. Or even up the voltage of your power supplies?.
    Apr 2004
    5419
    You probably need to cut the acceleration more radically than you've done. Cut it in half, and if that doesn't fix anything, cut it in half again. If that doesn't work, you've got to look at the whole machine and figure out what's hanging it up. I don't know if you're running ball screws, rack and pinion, or hardware store all-thread, or what you're using for linear slides - profile rails, round rails, dovetailed slides or what. You don't say what inductance those motors have or how much voltage you're feeding them. But any loss of mechanical advantage, increase in friction, binding, or burst of speed can cause lost steps, especially during cutting, if your motors are as marginal as they seem. NEMA 17 motors are okay for small 3D printers, but work less well for CNC machines that need enough power to overcome cutting forces. You might think about upgrading to low-inductance NEMA 23s.
    Andrew Werby
    Website
  1. Ah-Ha skipping steps only in 1 direction. Eh???
    By cnc1000 in forum Controller & Computer Solutions
    Last Post: 07-09-2013, 11:58 AM
  2. skipping steps (with video)
    By DanOSB in forum Stepper Motors / Drives
    Last Post: 01-16-2013, 05:37 AM
  3. Is this Skipping steps???
    By tdnp in forum DIY CNC Router Table Machines
    Last Post: 11-02-2012, 07:16 PM
  4. Skipping steps on the taig
    By nurp in forum Xylotex
    Last Post: 08-09-2009, 12:18 PM
  5. Stepper Skipping Steps
    By skartch in forum General CNC Machine Related Electronics
    Last Post: 10-27-2008, 11:27 PM
