531,689 active members*
2,171 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > SKT250LMS AL-60 turret index power off
Results 1 to 7 of 7
    Jan 2011
    350
    Hi guys,
    Can't find this alarm in the troubleshooting manual for this Hyundai Kia SKT250LMS with Fanuc 21i-TB control:
    Anybody has description for this or troubleshooting guide?
    Thanks.
    Jan 2011
    350
    This is caused by the turret amp that does not go to ready mode. Somehow this does not give any NC alarm, so a machine side alarm was created to detect this issue.
    Cheers.
    Nov 2013
    13
    2060 TURRET AMP ALARM
    Cause:
    - In case that alarm is issued on the turret AMP.
    Actions: /Procedures:
    - Take measures by means of reviewing the maintenance manual of FANUC I/O Link
    if any alarm is displayed on the turret AMP.
    Solution:
    - The confirmation contents of electric diagram as shown below.
    1) H/W
    - When the input signal X63.6 is “0”, it’s normal state.
    2) S/W
    - The confirmation state of A6.2 in PMC.
    Nov 2013
    13
    amp alarms:
    Attachment 211552
    Jan 2011
    350
    Ah yes thanks I forgot to post the solution on this thread. The alarm was caused by the turret being stuck out and it lost its index. Here is the solution:
    1: Press stand-by and reset for activating hydraulic pressure
    2: Activate manually the valve for unlocking turret, making sure inductive position detector lights up.
    3: Align turret dots by turning manually. (dots in my case but in some machines it's arrows, anyways it's easy to find)
    4: Activate manually the valve for locking turret, making sure inductive position detector lights up.
    5: Press on Call/BZ off
    6: Force X1000#7 to 1.
    7: Press on emergency stop.
    8: Press simultaneously Spindle Stop, mode Select and Feed Hold buttons.
    9: Release emg stop and restart the machine.
    Cheers all.
    Junior Member
    Nov 2018
    ok my problem solved, the problem was incorrectly saved parameters
    Oct 2009
    Re: SKT250LMS AL-60 turret index power off
    Quote Originally Posted by maxgreen View Post
    Have a similar problem. Would you by any chance recall what parameters was incorrectly saved
  1. Fanuc Oi-Tc Turret Mis Index(A0.3)
    By elab.ess in forum Fanuc
    Last Post: 02-26-2013, 07:27 AM
  2. Turret will not index as per commanded.
    By blakemachine in forum Fanuc
    Last Post: 01-09-2013, 10:07 PM
  3. Sl-10 Turret Index concerns
    By Mr.Xtreme in forum Haas Lathes
    Last Post: 02-02-2009, 06:43 PM
  4. Turret index speed
    By DocHod in forum Servo Motors / Drives
    Last Post: 03-07-2008, 04:24 AM
  5. Turret Index Only Once In Auto
    By rajesh_1355 in forum Fanuc
    Last Post: 01-29-2007, 12:48 AM
