585,557 active members*
3,233 visitors online*
Page 1 of 2 12
Results 1 to 20 of 29
    May 2017
    82
    Slave stepper motor
    Set up 4 motors on work bench to test it out, have channel 7 slaved to channel 0. X y z work in kmotion and slave for x works fine both motors turn the same.
    Set up a user button in kmotion with a move command Move(0,200) press button nothing happens and then x axis doesn't work. Changed program to do a Move(0,200) and a Move(7,200) and it works but why do I have to do two commands to move both if one is slaved?
    Also tried the same with a jog command had to enter two jog commands one for each x motor works but locks up if I do a Move command on x axis between jog commands.
    I could use some help in setting up my diy router, any one near Homer Glen Illinois?
    May 2006
    4045
    Re: Slave stepper motor
    Hi mirocha,
    Is Axis 0 the master or slave of Axis 7?
    Post your Initialization C Program so we can see how things are configured.
    Regards
    TK
    http://dynomotion.com
    May 2017
    82
    Worked on master slave problem and the more I attempted to solve the problem the worse it became with Windows 10 mouse becoming erratic. Dedicated computer just for the Kmotion. Reloaded Windows 10, reset PC, still a Windows problem. Found that the Logitech wireless optical mouse was using the windods generic driver was the problem. Installed the Logitech mouse driver fixed the windows problem and Kmotion seems to be working. The master slave of two stepper motors is working with the following ini file. Tested with a Jog(0,200) and Jog(0,0)command multiple times and both work.
    I am using 4 stepper motors all rated 1600-OZ, 3.5 amp, 5.7 volt with Gecko G210 drivers 10X microstepped, powered by 48 volts. All 4 motors are turning 5mm lead ballscrews.
    I do have the following questions regarding what the following settings should be, I am using the example file settings:
    1. Vel
    2. Accel
    3. Jerk
    4. MaxI
    5. invDistPerCycle
    6. StepperAmplitude
    7. Any other setting in the ini that should be adjusted.
    Any and all help will be appreciated.
    #include "KMotionDef.h"
    // Defines axis 0, 1, 2 as simple step dir outputs
    // enables them
    // sets them as an xyz coordinate system for GCode
    int main()
    FPGA(STEP_PULSE_LENGTH_ADD)=63+0x80; //set pulse length to 4us
    //and pulse high for gecko drives
    ch0->InputMode=NO_INPUT_MODE;
    ch0->OutputMode=STEP_DIR_MODE;
    ch0->Vel=40000;
    ch0->Accel=400000;
    ch0->Jerk=4e+006;
    ch0->P=0;
    ch0->I=0.01;
    ch0->D=0;
    ch0->FFAccel=0;
    ch0->FFVel=0;
    ch0->MaxI=200;
    ch0->MaxErr=1e+006;
    ch0->MaxOutput=200;
    ch0->DeadBandGain=1;
    ch0->DeadBandRange=0;
    ch0->InputChan0=0;
    ch0->InputChan1=0;
    ch0->OutputChan0=4;
    ch0->OutputChan1=0;
    ch0->MasterAxis=-1;
    ch0->LimitSwitchOptions=0x100;
    ch0->LimitSwitchNegBit=0;
    ch0->LimitSwitchPosBit=0;
    ch0->SoftLimitPos=1e+009;
    ch0->SoftLimitNeg=-1e+009;
    ch0->InputGain0=1;
    ch0->InputGain1=1;
    ch0->InputOffset0=0;
    ch0->InputOffset1=0;
    ch0->OutputGain=1;
    ch0->OutputOffset=0;
    ch0->SlaveGain=1;
    ch0->BacklashMode=BACKLASH_OFF;
    ch0->BacklashAmount=0;
    ch0->BacklashRate=0;
    ch0->invDistPerCycle=1;
    ch0->Lead=0;
    ch0->MaxFollowingError=1000000000;
    ch0->StepperAmplitude=20;
    ch0->iir[0].B0=1;
    ch0->iir[0].B1=0;
    ch0->iir[0].B2=0;
    ch0->iir[0].A1=0;
    ch0->iir[0].A2=0;
    ch0->iir[1].B0=1;
    ch0->iir[1].B1=0;
    ch0->iir[1].B2=0;
    ch0->iir[1].A1=0;
    ch0->iir[1].A2=0;
    ch0->iir[2].B0=0.000768788;
    ch0->iir[2].B1=0.00153758;
    ch0->iir[2].B2=0.000768788;
    ch0->iir[2].A1=1.92076;
    ch0->iir[2].A2=-0.923833;
    EnableAxisDest(0,0);
    ch1->InputMode=NO_INPUT_MODE;
    ch1->OutputMode=STEP_DIR_MODE;
    ch1->Vel=40000;
    ch1->Accel=400000;
    ch1->Jerk=4e+006;
    ch1->P=0;
    ch1->I=0.01;
    ch1->D=0;
    ch1->FFAccel=0;
    ch1->FFVel=0;
    ch1->MaxI=200;
    ch1->MaxErr=1e+006;
    ch1->MaxOutput=200;
    ch1->DeadBandGain=1;
    ch1->DeadBandRange=0;
    ch1->InputChan0=1;
    ch1->InputChan1=0;
    ch1->OutputChan0=6;
    ch1->OutputChan1=0;
    ch1->MasterAxis=-1;
    ch1->LimitSwitchOptions=0x100;
    ch1->LimitSwitchNegBit=0;
    ch1->LimitSwitchPosBit=0;
    ch1->SoftLimitPos=1e+009;
    ch1->SoftLimitNeg=-1e+009;
    ch1->InputGain0=1;
    ch1->InputGain1=1;
    ch1->InputOffset0=0;
    ch1->InputOffset1=0;
    ch1->OutputGain=1;
    ch1->OutputOffset=0;
    ch1->SlaveGain=1;
    ch1->BacklashMode=BACKLASH_OFF;
    ch1->BacklashAmount=0;
    ch1->BacklashRate=0;
    ch1->invDistPerCycle=1;
    ch1->Lead=0;
    ch1->MaxFollowingError=1000000000;
    ch1->StepperAmplitude=20;
    ch1->iir[0].B0=1;
    ch1->iir[0].B1=0;
    ch1->iir[0].B2=0;
    ch1->iir[0].A1=0;
    ch1->iir[0].A2=0;
    ch1->iir[1].B0=1;
    ch1->iir[1].B1=0;
    ch1->iir[1].B2=0;
    ch1->iir[1].A1=0;
    ch1->iir[1].A2=0;
    ch1->iir[2].B0=0.000769;
    ch1->iir[2].B1=0.001538;
    ch1->iir[2].B2=0.000769;
    ch1->iir[2].A1=1.92081;
    ch1->iir[2].A2=-0.923885;
    EnableAxisDest(1,0);
    ch2->InputMode=NO_INPUT_MODE;
    ch2->OutputMode=STEP_DIR_MODE;
    ch2->Vel=40000;
    ch2->Accel=400000;
    ch2->Jerk=4e+006;
    ch2->P=0;
    ch2->I=0.01;
    ch2->D=0;
    ch2->FFAccel=0;
    ch2->FFVel=0;
    ch2->MaxI=200;
    ch2->MaxErr=1e+006;
    ch2->MaxOutput=200;
    ch2->DeadBandGain=1;
    ch2->DeadBandRange=0;
    ch2->InputChan0=2;
    ch2->InputChan1=0;
    ch2->OutputChan0=7;
    ch2->OutputChan1=0;
    ch2->MasterAxis=-1;
    ch2->LimitSwitchOptions=0x100;
    ch2->LimitSwitchNegBit=0;
    ch2->LimitSwitchPosBit=0;
    ch2->SoftLimitPos=1e+009;
    ch2->SoftLimitNeg=-1e+009;
    ch2->InputGain0=1;
    ch2->InputGain1=1;
    ch2->InputOffset0=0;
    ch2->InputOffset1=0;
    ch2->OutputGain=1;
    ch2->OutputOffset=0;
    ch2->SlaveGain=1;
    ch2->BacklashMode=BACKLASH_OFF;
    ch2->BacklashAmount=0;
    ch2->BacklashRate=0;
    ch2->invDistPerCycle=1;
    ch2->Lead=0;
    ch2->MaxFollowingError=1000000000;
    ch2->StepperAmplitude=20;
    ch2->iir[0].B0=1;
    ch2->iir[0].B1=0;
    ch2->iir[0].B2=0;
    ch2->iir[0].A1=0;
    ch2->iir[0].A2=0;
    ch2->iir[1].B0=1;
    ch2->iir[1].B1=0;
    ch2->iir[1].B2=0;
    ch2->iir[1].A1=0;
    ch2->iir[1].A2=0;
    ch2->iir[2].B0=0.000769;
    ch2->iir[2].B1=0.001538;
    ch2->iir[2].B2=0.000769;
    ch2->iir[2].A1=1.92081;
    ch2->iir[2].A2=-0.923885;
    EnableAxisDest(2,0);
    ch7->InputMode=NO_INPUT_MODE;
    ch7->OutputMode=STEP_DIR_MODE;
    ch7->Vel=40000;
    ch7->Accel=400000;
    ch7->Jerk=4e+006;
    ch7->P=0.2;
    ch7->I=0;
    ch7->D=0;
    ch7->FFAccel=0;
    ch7->FFVel=0;
    ch7->MaxI=200;
    ch7->MaxErr=200;
    ch7->MaxOutput=200;
    ch7->DeadBandGain=1;
    ch7->DeadBandRange=0;
    ch7->InputChan0=5;
    ch7->InputChan1=1;
    ch7->OutputChan0=5;
    ch7->OutputChan1=1;
    ch7->MasterAxis=0;
    ch7->LimitSwitchOptions=0x100;
    ch7->LimitSwitchNegBit=0;
    ch7->LimitSwitchPosBit=0;
    ch7->SoftLimitPos=1e+009;
    ch7->SoftLimitNeg=-1e+009;
    ch7->InputGain0=1;
    ch7->InputGain1=1;
    ch7->InputOffset0=0;
    ch7->InputOffset1=0;
    ch7->OutputGain=1;
    ch7->OutputOffset=0;
    ch7->SlaveGain=1;
    ch7->BacklashMode=BACKLASH_OFF;
    ch7->BacklashAmount=0;
    ch7->BacklashRate=0;
    ch7->invDistPerCycle=1;
    ch7->Lead=0;
    ch7->MaxFollowingError=10000000;
    ch7->StepperAmplitude=250;
    ch7->iir[0].B0=1;
    ch7->iir[0].B1=0;
    ch7->iir[0].B2=0;
    ch7->iir[0].A1=0;
    ch7->iir[0].A2=0;
    ch7->iir[1].B0=1;
    ch7->iir[1].B1=0;
    ch7->iir[1].B2=0;
    ch7->iir[1].A1=0;
    ch7->iir[1].A2=0;
    ch7->iir[2].B0=1;
    ch7->iir[2].B1=0;
    ch7->iir[2].B2=0;
    ch7->iir[2].A1=0;
    ch7->iir[2].A2=0;
    EnableAxisDest(7,0);
    DefineCoordSystem(0,1,2,-1);
    return 0;
    May 2006
    4045
    Hi mirocha,
    The Init C File looks reasonable to me.
    1. Vel
    2. Accel
    3. Jerk
    Please see this article:
    Dynomotion
    4. MaxI
    You have an open loop system. P I D and other Feedback related parameters are not used.
    5. invDistPerCycle
    6. StepperAmplitude
    These only apply to modes where current cycles are directly applied to a motor (SnapAmp). It doesn't apply to Step/Dir Drives.
    Only those where you require that particular feature: Limits, Backlash, and OutputGain
    HTH
    Regards
    TK
    May 2017
    82
    I though I resolved the X axis master slave problem because the jog command worked. I set up two user buttons to run and stop the jog command to initiate the following two programs for jog. The first button runs following and both X motors in the X axis turn and the Kmotion display numbers advance. I can use the arrow buttons and the Y and Z axis work.
    main()
    Jog(0,2000); // move X axis
    Press the second button and both X axis motors stop and the Y and Z works from the Kmotion screen arrows.
    main()
    Jog(0,0); // Stop X axis
    I thought I resolved the X axis problem, I set up a third button but when I try a move command it will work only one time and then the X axis motors don’t work, the Kmotion screen display numbers advance for the X axis but the motors are not turning the Y and Z axis do work.
    main()
    Move(0,500);
    Thought may be I needed to de-slave the x axis so tried the following code but same thing, runs once, next time I try the Kmotion screen display numbers advance for the X axis but the motors are not turning the Y and Z axis do work.
    main()
    // Home (X0 and X7 are slaved)
    #define X0_AXIS 0
    #define X1_AXIS 7
    chan[X0_AXIS].MasterAxis = -1; // De-Slave both
    chan[X1_AXIS].MasterAxis = -1;
    Move(0,500); // move X axis
    Move(7,500); // move X axis
    chan[X1_AXIS].MasterAxis = X0_AXIS; // Slave X1 to X0
    chan[X1_AXIS].SlaveGain = 1;
    chan[X0_AXIS].MasterAxis = -1; // do not slave X0
    Jog command works on X axis master and slave no matter how many time I try no problem,
    Move command on X axis master slave only works once, then I move the x axis with the Kmotion arrows on the screen, the numbers advance but the motors don’t turn. it's like the X axis is locked out.
    Is there something I’m missing about the move command on a master slave axis?
    May 2017
    82
    Quote Originally Posted by mirocha View Post
    main()
    main()
    main()
    Move(0,500);
    main()
    #define X0_AXIS 0
    #define X1_AXIS 7
    It's as if Kmotioncnc is losing communication with the two gecko drives for the x axis after it completes one move command. Kmotioncnc looks like the x axis is working with The screen numbers for The x axis changing but The motors don't turn. The y and z axis work after a Move command they are not master slave.
    Jun 2004
    355
    If you run KMotion in the background with the Axis screen open, do both channels still show as being enabled, with the Dest column increasing when you press the button in KMotionCNC?
    It will also be worth having the Console window open in KMotion, to see if any messages get displayed.
    May 2017
    82
    Quote Originally Posted by m_c View Post
    Both channels remain enabled destination column increases when pressing button on Kmotioncnc there are no messages in console screen
    Jun 2004
    355
    That would indicate a problem outwith the KFlop. I've just had a quick look over the G201x/210x manual, and see no mention of any kind of LED. Are there any LEDs on the drives to give status? I'm wondering if there's something causing them to fault.
    What happens if you issue the move/jog commands via the Console?
    May 2017
    82
    Console?
    Gecko only has power on led. From console if I do a jog command I can do it as many times as I want and it works every time . If I do a Move command it moves the x axis two motors once and then the next time both x motors do not move from either console or Kmotioncnc. Tried move command for both Y and Z from console numerous times with no problem but they are single motors.
    Jun 2004
    355
    Do you have anything available to measure frequency? I.e. multimeter with frequency (Hz) setting, or oscilloscope.
    If you do, set it up so it's measuring the step pulse rate at the gecko drive. Do a move and see what reading you get, then do a second move and see if you still get a similar reading.
    Alternatively, do the first move, then reset the drives (having looked at the manual, you'll need to power cycle them - just turn of the power supply, wait until all drive lights go off, and power it back on), then try another move.
    What we really need to establish, is whether the KFlop is still outputting steps/pulses once the axes stop moving. The fact the Axis screen still shows movement, should mean that pulses are still getting generated, unless something else is causing the axis channels to be reconfigured and stop outputting the required pulses.
    It could be something going into fault when both drives are ran simultaneously, such as the regeneration/energy dump from two motors/drives decelerating causing a voltage spike. You could try reducing the acceleration value for the two axes (try dropping a couple or maybe even 3 zeros of the end), as that should reduce any resultant spike.
    Is it a switched mode, or unregulated power supply?
    May 2017
    82
    Lowered the acceleration starting with 3 zeros then went down to just reducing the acceleration by 1 zero and it is working, tried it a bunch of times worked every time no problem. The mean well power supplies I believe are switching type regulated. Now my question is the motors are running with no mechanical load, when I install them on the machine will there be a problem with the power supplies i'm using. The two x motors are rated at 3.5 amps each and the power supply is rated 10 amps. The y and z are rated 3.5 amps each and each powered by a separate 5 amp supply. Also is the lower acceleration rate acceptable for a 3 axis router. Why do I not have the same problem with single motors on power supplies rated half the amps. Would it benefit me to put large capacitors on the output of the power supplies.
    Why did it happen with a move command not with a jog?
    Would it be better to replace the 10 amp power supply wth two 5 amp supplies and power each motor seperately?
    Jun 2004
    355
    Regulated supplies are not ideal for stepper drivers. During motor deceleration, the stepper drivers dissipate the energy back into the power supply. With a regulated supply, they usually have no way of handling that, and depending on design can enter a fault mode and shut down, or if you pump enough energy back in, they simply go pop.
    Now when you add the additional load of moving an axis into the equation, you have even more energy being dumped, so the problem can become even bigger.
    There are a couple options. You could implement a reverse energy dump circuit. Gecko do have an application note with a circuit diagram - Returned Energy Dump | GeckoDrive
    Or swap the switched mode supplies for an unregulated supply. All you need is a suitable transformer, bridge rectifier, and capacitor. Again, Gecko have a basic guide in their stepper motor basics. Scroll down to Section 6, Power Supply Basics.
    Personally, I'd nearly always go for the unregulated option, as it's the simplest most robust option, but switch mode/regulated are usually more compact and lighter for a given output.
    May 2017
    82
    I ordered the parts for the reverse energy dump circuit and will see how well it works with regulated power supplies, geckos website states the reverse dump circuit protects both the drive and the stepper motor, they also say that with a unregulated power supply the capacitors suck up the reverse voltage, I would think it's never a good idea to backfeed voltage spikes into a power supply and would now probably add the reverse dump circuit even if I was using an unregulated supply, parts are less than $10.
    When I get the reverse dump circuit parts and installed I'll let you know how it works on my regulated power supplies, good or bad.
    Jun 2004
    355
    The benefit of an unregulated supply, is because they use a big capacitor for smoothing the supply, that same capacitor will absorb the energy. Yes, the voltage will rise, but provided there is enough margin in voltages, no damage will occur.
    Using a reverse energy dump, will also mean every time the motors decelerate, all that energy gets turned into heat, so you'll need to monitor the main resistor temperature, especially if doing lots of accelerating/decelerating.
    Jun 2010
    4256
    I would like to present a slightly different view of power supplies.
    When you are running a motor driver such as a Gecko (I only say 'Gecko' because I know them), then you are relying on some rather complex and very high speed digital and analog circuitry inside the box. This circuitry is EVERYTHING to the drive. Yes, I have designed such units myself.
    When you use a simple diode bridge and capcitor as the supply, you are giving the motor driver exactly what it was designed for: a nice quiet supply which can buffer any insults fed back into it. In general the motor driver does not care about the mains ripple it gets: it simply does not matter.
    But when you use a modern switched-mode PS you are feeding into the motor drive some extremely dirty, noisy power, full of RF noise, and that RF noise is quite capable of totally stuffing the system. It might not damage the internals of the controller, but it will sure as hell confuse it. If there is back-feed from the motor it may even damage the devices inside the PS box.
    The mfrs of these elegant modern Class-D H-mode motor drivers are not playing games when they specify a simple diode bridge & capacitor PS: they KNOW what they are doing. If I was a mfr I would simply refuse any warranty claims caused by using an SMPS instead of the simple diode/cap version. But what YOU do is up to YOU.
    Cheers
    Roger
  17. #17
    May 2017
    82
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    Roger I hear what you are saying and I will take your advice and use a diode/cap power supply, the gecko is rated for 80 volts, gecko recommends a power supply rated no less than 4 times motor voltage and no more than 20 times motor voltage. The motors I am using are rated 5.7 volts so I plan on using a 70 volt supply does that seem proper, it is my understanding the higher the voltage the more high speed torque so I will be changing the voltage from 48 volts (the original switching power supplies) to 70 volts (the new diode/cap power supply). Also I plan on making and using the gecko design energy dump circuit to further protect the gecko drives from back feed spike of motor regeneration or is this a mistake.
  18. #18
    Jun 2010
    4256
    Hi Mirocha
    I am running my Gecko servos at about 55 VDC, and they go just fine without missing input steps. So 70 VDC should be fine. I would not go higher.
    I have not put in any energy dump system as the 55 VDC is far enough down that I don't need to worry. But I have not seen any surges on the rail while machining, and I do have a voltmeter on the rail. Actually, the system draws only low current for most moves, except when drilling.
    Cheers
    Roger
  19. #19
    May 2017
    82
    I built the gecko "return energy dump circuit". My problem was with the 48 VDC "Mean Well" regulated switching power supplies my Y axis has two stepper motors and the Y axis would fail after the first deceleration. The X and Z axis single motors had no problem. I installed the gecko "return energy dump circuit" one each on the two Y axis stepper motors and it has not fail after numerous tests. I am going to change the power supply to a 70 VDC diode/cap unregulated power supply and will be using the return energy dump circuit. I know the circuit is working, it solved my problem for the regulated power supply. I would like to add an LED to the circuit to light when the circuit is shunting current to ground, I could keep an eye on it to see that it is still working. If any one with electronic knowledge could help me and add to the circuit attached what I would need to add a LED if it would work.
    Attachment 364942
  20. #20
    Jun 2010
    4256
    You could add an LED to let you know when the dump has been activated, but you will probably only get very brief flashes. Fractions of a second is all one would expect.
    The circuit you are showing looks wrong to me. You have the current from the supply going through a 1kohm resistor - that would never work at any power level! If you changed the 1k resistor to 1 ohm it might work - maybe.
    It is a bit hard to say how to add an LED without more details. Assuming that we are talking about a +70 VDC supply, that means the collector of the transistor may rise to about +70 V. In that case you could put a LED in series with a resistor across the 33 ohm resistor. The anode of the LED goes to the collector, and the resistor should be about 70 V / 0.01 A = 7,000 ohm - say 6.8 kohm ( to ground).
    Cheers
    Roger
Page 1 of 2 12
  1. mach 3 slave motor(stepper) turns only one direction??
    By xkadet in forum Machines running Mach Software
    Last Post: 01-03-2013, 09:59 PM
  2. Question about slave stepper
    By jzurek in forum DIY CNC Router Table Machines
    Last Post: 03-05-2011, 01:48 AM
  3. Slave Stepper Question
    By mlk1950 in forum DIY CNC Router Table Machines
    Last Post: 11-27-2010, 03:18 AM
  4. 4th Axis Slave Stepper or Not?
    By Dusty Mills in forum DIY CNC Router Table Machines
    Last Post: 03-26-2010, 02:46 AM
  5. what is to "slave" a stepper motor?
    By salvaCNC in forum Stepper Motors / Drives
    Last Post: 12-03-2007, 10:41 PM
