My mill is using Linux v2.30 and CNC10, from a report file:
CNC10CONV v. 2.32 - Centroid configuration file utility
CNC10 Uniconsole-2 v. 2.32 setup file for CPU7
There's a solid state drive.
File operations that require a directory display have always been horribly slow, as in 45-70 seconds. Then when I get the screen and I want to select to read off the USB drive it takes another long wait for that new file display to happen.
I can remember 8086 DOS PCs with floppies being waaaay faster.
Is this something peculiar to my machine or is that just the way the older Linux systems are?
I'll grant that this is not a "problem", just an annoyance, and other than this I'm happy with the control, but if I'm changing between several small programs it gets a bit tedious.
thanks,
Michael
