549,872 active members*
2,102 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Slow variation of spindle RPM under Mach3 control
Results 1 to 4 of 4
    Mar 2019
    My spindle RPM slowly goes up and down. from 10000 up to 13000 and back to 10000 in 5 - 6 seconds period. Tachometer measurements coinside with VFD.
    Set up: Mach3 - Huanyang VFD (110V, 2.2 kW) and 110 V 2.2 kW spindle.
    If I set J1 jumper to VR position - RPM fluctuation disappear (some variation on the level of 100 RPM at set value of 15000 is tolerable)
    With jumper in VI position (PWM control from RNR USB breakout board) RPM fluctuates within 20% of the set value.
    There are also difference between set value and real average RPM value: At 10000 RPM set on Mach3 spindle RPM fluctuates around 12000 RPM.
    I check PWM signal on VI terminal with oscillopscope - it is fairly clean.
    Any help is highly appreciated.
    Community Moderator Al_The_Man's Avatar
    Dec 2003
    23820
    Re: Slow variation of spindle RPM under Mach3 control
    What PWM freq. rate are you using?
    Does it vary much according to the 'scope trace?
    Albert E.
    Jun 2005
    1392
    I had this issue years ago, the solution was to get larger gauge wire that went from the analogue control to the VFD.
    Jan 2005
    13253
    Quote Originally Posted by chromvis View Post
    This can be expected when running this 2.2Kw spindle on 120v single phase supply there is more than just the PWM at play with this setup, lack of power supply is your biggest problem
    1.5Kw is the limit if you want a spindle to run half decent on a 120v single phase supply
    If you live in NA, you don't have a 110v supply it is 120v
    Mactec54
  1. Spindle rpm slow down when jog any axis (Mach3)
    By SAMI81 in forum Mach Software (ArtSoft software)
    Last Post: 01-19-2019, 05:10 AM
  2. Mach3 and Spindle motor from China running in slow RPM
    By pelo13 in forum Mach Software (ArtSoft software)
    Last Post: 08-01-2015, 02:43 PM
  3. New Quirk = Spindle running SLOW, at wong RPM??
    By RussMachine in forum Tormach Personal CNC Mill
    Last Post: 05-14-2014, 06:14 PM
  4. RF45 issue: spindle slow to reach max rpm
    By spv123 in forum Benchtop Machines
    Last Post: 01-07-2013, 05:50 AM
  5. Spindle Speed Variation Control
    By gunda in forum Okuma
    Last Post: 01-31-2012, 10:38 PM
