Just bought and set up a new to me techno lc4896 with a tool changer and vacuum hold down. I am waiting on the PO to transfer the Vcarve software over to me so I can design using that. In the meantime I wanted to test out the machine and was using the simple Carbide 3d Pro to generate gcode to run it. It worked great to flatten the mdf table. I need to hog out some blanks to put on a lathe before turning the details and thought this would work as a good test. Did my design in Carbide the saved the gcode brought it over to the CNC and set up the job. It is a series of circles and the machine is cutting a microscopic version of the job. I tweaked the design 4 or 5 times with same result. Any thoughts on how to correct this? Thanks
