544,018 active members*
2,430 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > General Waterjet > sodick AQ535A ERROR 00164 short circuit (ST)
    i have this problem with my machine (ST) is on when i start run the program, i can do dry run but i cant have the arc when i run the program.
    Jun 2021
    Re: sodick AQ535A ERROR 00164 short circuit (ST)
    I have the same problem
    Jun 2021
    Hmm, an interesting problem. I once had something similar, I spent a lot of time and effort to fix this failure. I once spoke to a friend of mine, he is a Level 2 Electrician Penrith . He checked the grounding and the power distributor. He was able to repair my car. I mean, you can't solve the problem alone. It is better to entrust the case to a professional and everything will be fine. I also advise you to trust only reliable masters, because it is not uncommon that they intentionally damage cars so that you return to them and pay money again. good luck and bye. I hope I was able to help you with your problem and it will not bother you
  1. sodick AQ535A ERROR 00184 MOTOR ERROR
    By mahmoud76 in forum General EDM Discussion
    Last Post: 02-14-2020, 10:45 PM
  2. Short Circuit I think???
    By katerina4 in forum General EDM Discussion
    Last Post: 12-08-2017, 11:22 AM
  3. REGULATOR SHORT CIRCUIT
    By Arjuna in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 04-05-2013, 10:13 AM
  4. Short circuit protection
    By Beaker in forum General CNC Machine Related Electronics
    Last Post: 10-07-2009, 12:16 PM
  5. Short circuit question
    By Tomax in forum General CNC Machine Related Electronics
    Last Post: 04-30-2008, 03:46 AM
