545,767 active members*
1,834 visitors online*
Results 1 to 7 of 7
    Jul 2021
    Solenoid Valve
    Trying to find solenoid valve for a gear shift issue on my Kuraki KBT-11.
    Thank You in advance.
    Community Moderator Al_The_Man's Avatar
    Dec 2003
    23736
    Re: Solenoid Valve
    What is wrong with the solenoid?
    Have you contacted a local hydraulic supply house, usually they are able to sub a replacement.
    Albert E.
    Mar 2009
    1577
    Re: Solenoid Valve
    Three valves on the block in the picture. Two of them bi-directional. Activate it with screw driver to see what it is responsible for.
    Make sure it is safe to activate in advance.
    Dec 2003
    23736
    Re: Solenoid Valve
    Quote Originally Posted by Algirdas View Post
    If these are AC valves, if any side is activated manually that happens to be under power at the time, means an instant coil burn-out!
    Albert E.
    Mar 2009
    1577
    Re: Solenoid Valve
    1. Sure no.
    2. Disconnect electrical connector and activate with screw driver then. Would be safe.
    Dec 2003
    23736
    Cool Re: Solenoid Valve
    I saw it happen plenty of times with mechanical maintenance service teams.
    One of the reasons I always spec'ed in DC coils for new projects, it can't happen with DC.:idea:
    Albert E.
    Dec 2009
    684
    Re: Solenoid Valve
    1. Sure no.
    Remember that the gear box changing must include the slow spindle rotating while shifting so if you do it by hand ,put a guy to rotate slowly the spindle while you are actuating the valve.
  1. Need help adding solenoid valve for coolant.
    By JDG3 in forum Shopmaster/Shoptask
    Last Post: 11-02-2016, 09:00 PM
  2. Solenoid valve question
    By scrambled in forum General CNC Machine Related Electronics
    Last Post: 11-24-2010, 04:23 AM
  3. PLC stops when solenoid valve activated
    By Syphonics in forum General CNC Machine Related Electronics
    Last Post: 09-24-2009, 12:59 AM
  4. solenoid valve for atc
    By ged in forum General CNC Machine Related Electronics
    Last Post: 03-14-2009, 11:30 PM
  5. Oxygen Pierce solenoid Valve
    By roady89 in forum General Waterjet
    Last Post: 10-05-2007, 11:11 PM
