585,906 active members*
3,845 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Solid State Relay for 220 volt single phase motor
Results 1 to 7 of 7
    Nov 2017
    9
    Currently using a solid state relay with input 3-32 VDC, Output voltage 24-380 VAC and Output current 25A to power on/off 1 HP 110 volt electric motor. The current relay has only one connector for the 110 volt input and load side wire. I want to upgrade motor to a 3HP 220 volt . Any thoughts on a solid state relay which will work for this 220 volt application? Can I add another relay and use in parallel?
    Sep 2005
    1195
    Re: Solid State Relay for 220 volt single phase motor
    That Fotek relay can be used for 220VAC ?
    Dec 2013
    5717
    You could use 2 of those to switch both sides of the 220 line. I have not seen a single solid state relay with two line and load terminals.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2003
    35538
    You could use a contactor.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2007
    2083
    how about a dual SSR
    Attachment 404216
    basically two solid state relays in one package
    for 3 phase motors you have these 3 phase SSR's
    Attachment 404218
    3 Hp is only 2.2Kw so at first sight a 25A rely will be OK
    but you need to have a relay that can withstand the start up current
    just beware from places like ebay some of the solid state relays are fake !!!
    https://www.youtube.com/watch?v=DxEhxjvifyY
    John
    Jan 2005
    15362
    Quote Originally Posted by Jim Dawson View Post
    Yes most manufacturers make them, I have used them many times, they are normally expensive but here is a cheap one and a more expensive one
    Holdwell Dual Solid State Relay SSR 17-32VDC Input 280VAC 40A Random or a Crydom D2440DE-10
    Mactec54
    Dec 2013
    5717
    Cool, never really looked for one before. Good to know.
    Jim Dawson
    Sandy, Oregon, USA
  1. Wiring the SSR SOLID STATE RELAY
    By alhaddar in forum Open Source CNC Machine Designs
    Last Post: 07-07-2014, 12:52 PM
  2. solid state relay to control lathe motor...anithing alse?
    By patriciooholegu in forum CNC Machine Related Electronics
    Last Post: 12-21-2010, 11:21 PM
  3. 24Vdc Solid State Relay not the same as mechanical relay??
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 11-10-2010, 07:40 AM
  4. Using a solid state relay as a main stop relay
    By garagefela in forum CNC Machine Related Electronics
    Last Post: 02-26-2010, 11:27 PM
  5. Solid state relay
    By N4NV in forum CNC Machine Related Electronics
    Last Post: 05-07-2006, 06:19 AM
