The ssr works and kicks on no problem IF i use a 6v battery pack to juice it.
If i use the BOB it doesnt. I have everything setup correct and mach3 is controlling the Pinoutput fine.
The problem i have is before i attach the ssr i get 4.99v across the gnd and output pin from the BOB. Once attached to the SSR it drops to 2.8v
I add 5v 1.2a power supply to my BOB but it doesnt help.
When the battery is plugged in and i check, the voltage is the same as when the battery is unplugged.
I get the idea that voltage drop could be due to lack of mA but a 1.2amp supply should be enough. What am i not getting or understanding?
TIA!
Eric
