IguDNCLink is a modern data management solution for handling CNC machine programs.
Video here (AI)
This easy-to-use application automates the naming of NC files directly from, for example, comment fields and saves them to the correct folders instead of the traditional O+4 digit format.
IguDNCLink seamlessly integrates with CNC machine manufacturers' applications, such as USB transfer, Fanuc Program Transfer Tool, Mori Server, and HH Remo. The issue between the RS-232 era and the latest RJ-45 connections that allow longer filenames is often resolved with this solution. It ensures that the program is automatically saved, even when transferred via USB or the machine manufacturer's own link, such as the Program Transfer Tool. These tools save it as O1234, and we automatically convert it to a long name in a workstation or server folder.
When you use IguDNCLink, program files are named and saved automatically in the correct location, reducing confusion and improving production efficiency. At the same time, the program handles automatic versioning and backup to the BACKUP folder. IguDNCLink also functions as a handy archiving tool, allowing you to easily find the desired NC program, add and retrieve notes, and open programs in an editor with just one click.
IguDNCLink can also act as a data transfer link (optional) for older CNC machines, enabling program transfers over the network to the correct location. Ask for more information at [email protected] or send a sample program from which you'd like a long save name.
Best Regards: i-GuSystem Finland
