585,722 active members*
4,040 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Some real basic (stupid) questions about Mastercam issues
Results 1 to 4 of 4
    Aug 2010
    5
    Hello,
    I am struggling through tutorials and experiments but have a few real basic questions.
    Maybe someone here has the answers?
    1) When I use the Wireframe Tab and create a rectangle with that: Why then can I not extrude this rectangle? It is always "Thickening operation failed"
    2) If I create a solid block with the block option and then try and do a profile along it's side, I cannot get it to do any 2D contour depth cuts or anything as the edges are not selectable. But If I select the whole side surface, the routing path does not work as expected and want to start at the bottom and work upwards, in effect crashing the tool.
    3) If I import a .step file from Solidworks, with a part in it, none of the part seems to be recognised as "toolpathable". Whilst I can select the edges and stuff, it just does seem to want to do anything useful with them. How do I convert a step file into something usable in Mastercam?
    So far, the only thing that I can get to work is if I draw the rectangle from separate splines. It can then be extruded, cut etc.
    Regards
    Bernt
    Apr 2003
    3578
    Re: Some real basic (stupid) questions about Mastercam issues
    What version of Mastercam are you using?
    (I am struggling through tutorials) were are getting these tutorials from a book or online videos?
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Aug 2010
    5
    Quote Originally Posted by cadcam View Post
    2018
    I used videos and some pdfs.
    It still does not work any better.
    Apr 2003
    3578
    Ok so an older MC but a good one.You used training videos from were. were they showing properly how to use the tools. Sounds like not.
    Now if you create a rectangle from the top plane and then go into Solids and do extrude and give it only a positive value based on the arrow direction you should get a result.
    As for the contour issues are you sure it is a solid and not a surface model? and are you trying to use wire selection as it is the default in that version instead of solid selection?
    Cadcam
  1. Replies: 9
    Last Post: 11-21-2012, 03:23 PM
  2. Stupid beginner questions
    By Beezle in forum Tormach Personal CNC Mill
    Last Post: 10-09-2010, 05:41 AM
  3. Time for a real stupid question
    By sdantonio in forum DIY CNC Router Table Machines
    Last Post: 11-17-2005, 11:43 PM
  4. real basic question.
    By quammi in forum Autodesk
    Last Post: 08-21-2005, 09:28 PM
  5. Real stupid question
    By lsippell in forum CNC Machine Related Electronics
    Last Post: 07-22-2004, 03:11 PM
