562,315 active members*
3,140 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Spectroid app as tachometer.
Results 1 to 19 of 19
    Dec 2005
    306
    Hi Folks.
    Did you know you can use the spectroid app on a android smartphone as a tachometer.
    If you put a little piece of tape as a flag on the spindle, the sound is measured and the frequency in hertz is displayed as a number in the chart in spectroid.
    Sometimes you have to change the settings of spectroid to display more the one frequency as a number.
    Sep 2021
    8
    Re: Spectroid app as tachometer.
    Quote Originally Posted by vroemm View Post
    Hi Folks.
    Did you know you can use the spectroid gbwhatsapp app on a android smartphone as a tachometer.
    How? do you please share more details about this proccess as you are saying about this spectroid application.
    Dec 2021
    3
    Hi Folks.
    Did you know you can use gb whatsapp the spectroid app on a android smartphone as a tachometer.
    Thanks! I use Android app Spectroid and it works like a charm. Looks like my saw is spinning at around 2000 rpm, seems like a right number.
    Jan 2022
    6
    No, I know use the spectrometer app on an android smartphone as a tachometer. You have shared very good information, your this app, is very helpful for me. Thanks for sharing this information with all of you.Kinemaster Mod Apk
    Jun 2022
    3
    Are there any chances of adding a feature to the spectroid mod apk to export the spectrum data from it?
    Aug 2022
    5
    Hey Folks.
    Did you realize you can utilize <a href="https://gbwhatsapp.net/">gb whatsapp</a>
    the spectroid application on an android cell phone as a tachometer.
    In the event that you put a little piece of tape as a banner on the shaft, the sound is estimated and the recurrence in hertz is shown as a number in the graph in spectroid.
    In some cases you need to change the settings of spectroid to show more the one recurrence as a number.
    Aug 2022
    5
    Hey Folks.
    Did you realize you can utilize <a href="https://gbwhatsapp.net/"> gb whatsapp </a>
    Aug 2022
    I liked your article, I thought I would get the mod apk version of Spectroid app at ModCombo. ModCombo is always a great choice whenever I want to download mod apk version apps.
    Aug 2022
    I liked your article, I thought I would get the mod apk version of Spectroid app at https://modcombo.com/id/ . ModCombo is always a great choice whenever I want to download mod apk version apps.
    Aug 2022
    3
    I used this app, but why there are discontinuities in the spectrum graph?GBWhatsApp APK
    Sep 2021
    9
    Quote Originally Posted by justin007 View Post
    https://gbwamod.com/download-fmwhatsapp-apk/ has features not available in the original app. You can focus on the possibilities of applying these new resources to your entire marketing and sales strategy.
    It is a best app with a lot of exciting features.
    Aug 2022
    Quote Originally Posted by JaimeLong View Post
    I liked your article, I thought I would get the mod apk version of Spectroid app at https://uptomods.com/ . Uptomods is always a great choice whenever I want to download mod apk version apps.
    I agree with you
    Aug 2022
    When the light's flicker frequency coincides with the rotating frequency of an object, such as a fan, the rotating fan may appear stationary.
    Aug 2022
    By changing the flicker frequency of the light, the rotation speed can be determined. I, for example, do something like that when I visualize and save rotation data of rotating devices. You have to put your phone on a turntable and let the app do the rest. The app uses your phone's IMU sensor to do the calculations. The accuracy of the results depends on the resolution of your phone's sensor. I found an app like this on https://www.apkdojo.com/vidmate when I downloaded the Vidmate app to work with my videos.
    Jul 2021
    11
    It sounds unreliable, just like other programs on the phone, which only in theory seem to be working and useful.
    Sep 2022
    When the flickering frequency of the light matches the rotating frequency of an object, such as a fan, the rotating fan can appear stationary. See here: https://goappsplay.com/kinemasterdiamondmodapk/
  17. #17
    Oct 2022
  18. #18
    Oct 2022
    See the place to download more: https://technifiser.com
  19. #19
    Aug 2022
    5
    requency Meter PRO is a comprehensive tool for audio frequency diagnostics. Includes REAL TIME scanning of audio signal from internal or external microphone. Application is calibrated with real tone generator. Working range is around 15 - 22500 Hz, and accuracy around +/- 0.5 %.
    https://findtricks.in/
  1. Tachometer
    By Sixgun in forum General CNC Machine Related Electronics
    Last Post: 05-07-2011, 10:09 PM
  2. Tachometer feedback???
    By motter71 in forum General MetalWork Discussion
    Last Post: 08-21-2009, 10:27 PM
  3. Tachometer?
    By John3 in forum Gecko Drives
    Last Post: 09-25-2007, 04:57 AM
  4. How can I check a tachometer?
    By asantos in forum Servo Motors / Drives
    Last Post: 02-20-2007, 12:46 AM
  5. Homemade tachometer help
    By Smurf208 in forum General CNC Machine Related Electronics
    Last Post: 11-02-2006, 06:39 AM
