601,789 active members*
2,595 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > SPINDLE BELT REPLACEMENT Doosan DNM400, Serial MV00009-001210
Results 1 to 5 of 5
    Mar 2017
    Question SPINDLE BELT REPLACEMENT Doosan DNM400, Serial MV00009-001210
    Hello and thanks for having me.
    I am attempting to replace the spindle belt on our Doosan DNM400, Serial MV00009-001210 . I have the bolts free on the pancake cylinder up top. The stop plate visible only through the little window in front of the machine will only turn a little in each direction until it fully stops hard. From another post on this subject I have attempted to place a 5mm bolt into the stop plate and loosen it so that I can remove the assembly to no avail. The instructions I followed were:
    1) remove the 4x M8 bolts holding the cylinder down to the black base plate, remove cylinder.
    2) Remove the 6x small bolts in the ring that times the drawbar to the spindle, remove the ground "rod stopper".
    3) The stopper is a threaded ring. Insert one bolt into any of the 3x holes in the face of the "End stopper", stack up washers under the allen head to prevent bending the bolt. Strike the bolt with a brass punch to rotate the stopper in a counter clockwise direction (Righty tighty, lefty loosie).
    4) Pull out the base plate and you're good to go. You have access to install the belt
    As I stated I can move the "stopper" 0310 C72041224A one direction or the other but it eventually hits a hard stop and will not go any further. Fearful of breaking something I thought I would inquire about other's experience. Need to get this bad boy up and running pronto!
    Feb 2013
    788
    Re: SPINDLE BELT REPLACEMENT Doosan DNM400, Serial MV00009-001210
    This is Darryl Hardt with Doosan Machine Tools.
    Call my desk for assistance 973-618-2461
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Feb 2013
    788
    Referring to the colors of the attached drawing:
    Remove all hoses and switches attached to the actuator
    Remove the orange cover
    Remove the pink TSC mount
    Remove the green union
    Remove the yellow cap
    Remove the green "spring-screws"
    Remove the cyan cap-screws that hold the top of the actuator to the bottom flange
    Lift the actuator top assembly off...this may require rotating the spindle by hand to align a "bowtie" keyway.
    Mark the yellow stop-ring's location for alignment to the brown spindle core
    Note the location of the Pink balance screws
    Remove the bolts on the dark gray end cap that holds to the brown spindle core
    Loosen/remove the red locking setscrews that keeps the yellow stop-ring onto the brown spindle core (note: likely to be Left hand thread)
    Lift off red bottom flange
    Remove belt
    install new belt
    reverse process (ensuring the yellow stop ring lands back at the exact same orientation to the brown spindle core)
    Timing belts look like |||||||||| while Eagle belts look like >>>>>>>>>>>>>
    Note: Eagle belt (>>>>>>>>>>>) tension MUST be done with a frequency analyzer
    Nov 2007
    361
    Hey dhardt I have a dnm 500 and I need to replace the spindle belt on it , I was wondering if this diagram and steps to remove the top end would be the same on the dnm 500 ? If not can you send me the steps and diagram so I can get the belt changed . If it is the same can you give me any info I will need to change it
    Mar 2011
    4
    how is your PRONTO going?
  1. DOOSAN DNM 400 BELT BORKE
    By STARSR20J in forum BobCad-Cam
    Last Post: 01-27-2017, 08:06 PM
  2. Replies: 0
    Last Post: 09-13-2016, 11:15 AM
  3. Doosan DVM400 spindle belt
    By Artesian in forum Daewoo/Doosan
    Last Post: 02-22-2012, 01:11 AM
  4. Serious Doosan DNM400 issue.
    By motordude in forum Daewoo/Doosan
    Last Post: 02-27-2011, 10:49 PM
  5. Doosan DNM400 vs Haas VF2
    Last Post: 12-21-2010, 06:28 PM
