585,717 active members*
4,048 visitors online*
Results 1 to 4 of 4
    Apr 2010
    Post SPINDLE ERR 18 BAT TL
    Hi
    We have a VICKERS DRIVER MODEL VFS5-275-00-2606/A with a compensation module 275/2604A-010.
    We connect the MOTION LINK PLUS SOFTWARE and appears the ERR 18 BAT TL FILE
    The VFS5 has two boards: MC board and IBD board the two cards are the same that we are using before.
    We have the TL VFS5 v 1.03cC file and we compare this with the system in and are the same.
    We have the encrypted Key number 1991923109, but we dont have the unlocked number to transfer again the TL file and Variables, Do you know how to correct this, please inform us.
    Oct 2008
    123
    hello what machine ( what control is on it ) is this for?
    what is the encrypted number for?
    regards
    mallardfizz
    Aug 2008
    97
    not familar with some of what you are saying but is this where you would go to ml terminal with motion link plus and type new then if on a2100 type a2100 and then it will let you save variables to drive. But also cincinatti only changes a few of the user variables and some you can not change. Also i don't have a vfs5 manual here with me but there is a battery in the vfs5 and i'm not sure which board it is on but where your alarm reads bat tl i would check my manual to see if there is battery that is dead. I may be way off but trying to help so sorry if i miss inform. I will check your alarm in manual tommorow when at shop and see if i can offer more help.
    Nov 2021
    25
    Re: SPINDLE ERR 18 BAT TL
    I have exactly the same error!
    What else to try...
    Or just send it in for repair!
    [email protected]
  1. Mini Mill X2 Spindle Head + VFD + Chinese Spindle= custom!
    By diyengineer in forum Uncategorised MetalWorking Machines
    Last Post: 12-26-2016, 10:04 PM
  2. Replies: 5
    Last Post: 07-19-2013, 05:16 AM
  3. VistaCNC iMach 3 Spindle Tachometer causing inconsistent spindle speed
    By QueueJr in forum Uncategorised MetalWorking Machines
    Last Post: 07-03-2012, 01:46 AM
  4. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
  5. Replies: 4
    Last Post: 10-15-2010, 07:10 PM
