562,565 active members*
2,769 visitors online*
    Nov 2022
    Spindle Not Turning
    I am not sure where to start. I have Mach 3 and the USB Motion Board AKZ250 I have a 220 v 2.2kw 400hz water cooled spindle and the Hyuang ( spelling) VFD. It was working fine, then when the file ended it would not shut all the way off, so I turned the power off to the Hyaung VFD, then powered back up now the spindle wont turn at all. If someone could point me where to start I would appreciate it? Thanks
    Nov 2022
    Re: Spindle Not Turning
    I also forgot to mention that I switched settings under Ports and Pins/Spindle Setup, with the dust collection and it worked under the spindle output. So I guess the output signal is good.
    Jan 2005
    14730
    Quote Originally Posted by Dooley View Post
    How did you power off the VFD Drive??
    Does the VFD Drive still power up??
    How have you wired it. Post some Photos or if you can't post photos, a good description of how you have wired it, have you used a Relay for the FWD DCM connection
    Mactec54
