504,500 active members
3,533 visitors online
Results 1 to 9 of 9
    Spindle speed
    Hi all!
    Got my new pro series plug’n’play machine running but can’t seems to figure out how to get the spindle to run higher than 12000. I can adjust slower in Mach 3 but nothing higher than 12000. It should be able to run 24000.
    Thanks!
    Feb 2005
    744
    Re: Spindle speed
    have you reached out to AvidCNC for support, they are usually very knowledgable.
    Company Representative
    Oct 2005
    819
    Re: Spindle speed
    What kind of VFD you have?
    What is the Frequency did you set?
    if you have the HY VFD, you need to set PD144 to 3000
    Check here:
    https://www.automationtechnologiesin...-110vac-input/
    Quote Originally Posted by automationtechinc View Post
    Check here:
    Thanks!
    I’m running the 2.2kw plug and play spindle/ vfd system.
    GMT 2.2 kw (3hp) air cooled
    Thanks-
    Apr 2016
    770
    Re: Spindle speed
    Quote Originally Posted by Brandnewnoise View Post
    Thanks!
    Thanks-
    I guess it's not so plug and play. As nlancaster suggested, reach out to CNCRP/Avid CNC. In the interim, since it's a weekend, you may want to check your Spindle Pulley setting in Mach3. It's under the Config menu. If you don't have it set right, you can get what you are seeing. (Been there, done that). Minimum should be 0. Maximum should be 24000. Ratio should be 1.
    Gary
    Feb 2005
    744
    Re: Spindle speed
    oh yeah, pulley setting tripped me up too in mach3. When I setup my HY VFD and Chinese Spindle.
    May 2018
    5
    Re: Spindle speed
    Minimum should be 8000 unless you want to burn your bearings up. Less than 8000 it won't produce enough air flow to cool it.
    Apr 2016
    770
    Re: Spindle speed
    Quote Originally Posted by mpoling View Post
    Good point. I forgot that we're talking air cooled. Mine is liquid cooled, so no worries for me.
    Re: Spindle speed
    Thanks! I ended up needing to do a reinstall of Mach 3. That seemed to have fixed all issues related to the spindle speed but thanks for the heads up about spindle pulley settings. Will most certainly come in handy in the future.
  1. Replies: 3
    Last Post: 04-20-2019, 11:24 PM
  2. Replies: 0
    Last Post: 06-10-2016, 03:08 AM
  3. Fanuc AC Spindle Drive speed does not match S-code speed
    By serickson in forum Spindles / VFD
    Last Post: 10-13-2014, 01:18 PM
  4. Replies: 1
    Last Post: 08-02-2013, 10:07 PM
  5. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
