554,132 active members*
3,824 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Spindle Speed Variation
Results 1 to 5 of 5
    Oct 2016
    66
    speed shown on VFD display does not match that set on UCCNC.
    • UCCNC set to 6,000 RPM - VFD Display fluctuates constantly from 10,300 up to 10,900 then down. ( Analog voltage on board 2.62V)
    • UCCNC set to 12,000 RPM - VFD Display fluctuates constantly from 14,200 up to 15,200 then down. ( Analog voltage on board 4.87V)
    • UCCNC set to 24,000 RPM - VFD Display without fluctuation 22,812 ( Analog voltage on board 9.33V)
    The 10V supply from the VDF reads out 9.97V at the controller board (UB1), so did a little experiment and provided 10.2V by independent PS. This didn't really helped.
    • UCCNC set to 24,000 RPM - VFD Display without fluctuation 23,028 ( Analog voltage on board 9.46V)
    The VFD I have is
    HY02D223B coupled to a 400Hz spindle 220v - 2.2W water cooled.
    PD settings on the VFD:
    Jumper set on connection 1 & 2 for remote terminal control
    PD001 1
    PD002 1
    PD003 400
    PD004 400
    PD005 400
    PD007 20
    PD008 220
    PD009 15
    PD010 11
    PD011 100
    PD014 10
    PD015 10
    PD041 8
    PD052 1
    PD070 0
    PD072 400
    PD073 100
    PD120 100
    PD141 220
    PD142 9
    PD143 2
    PD144 3000
    What could be causing this variation in speeds?
    Thanks in advance!
    Nov 2012
    1218
    Re: Spindle Speed Variation
    What is your PD 071 (Analog Filtering) set to? Try increasing it.
    Oct 2016
    66
    Quote Originally Posted by CitizenOfDreams View Post
    PD 071=20
    Tried 30,35,40,50 and no real change, issue remains.
    I also tried having a dedicated shielded cable for the 10v, 0v, and analog signal from controller board to vfd but issue remains. Thought it was a noise issue because of how the speed increases then decreases then increases and so on.
    I checked the settings on UCCNC for the PWM frequency and was set to 400 hz while the manual for the bob (ub1) recommeneded 1524 hz so I used this value. This change helped getting ride of the variable speeds. When set to 12,000 on uccnc, vfd now reads 15144 then goes up to 15 162rmp for a second then down to 15 144. This small variation is acceptable but how can i tweak the settings to get 12 000 rpm at the vfd when that value is set on uccnc?
    Jan 2005
    14298
    Quote Originally Posted by Phil_Par View Post
    PD 071=20
    How many Amps is your 240v supply to the VFD Drive
    Mactec54
    Jan 2005
    14298
    PD 071=20
    You first have to correct the 0-10v Analog output at the Board level before you do anything with the VFD Drive, 1524hz does not sound correct for the PWM to Analog 0-10v normally 100Hz is what is used
    Mactec54
  1. Spindle variation on cnv
    By tshawkins in forum Milling
    Last Post: 10-15-2019, 04:36 AM
  2. Spindle Speed Variation Control
    By gunda in forum Okuma
    Last Post: 01-31-2012, 10:38 PM
  3. macro for spindle speed variation
    By lovetofish89 in forum Fanuc
    Last Post: 04-09-2010, 09:59 PM
  4. TL-1 SSV (spindle speed variation)
    By xyzcnc in forum Haas Lathes
    Last Post: 07-25-2007, 05:48 AM
  5. How to modify HPLG file to compensate for the speed variation of my laser engraver ?
    By g1zmo in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 05-10-2007, 04:16 AM
