552,801 active members*
2,202 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Spindle won't turn on VM5020
    When looking at diagnostics the zero speed input is on. When I do a tool change the spindle will orient itself correctly, but when I try to turn on the spindle (s2000 M3), it doesn't spin but I am getting V1-01= 66.5Hz on the drive. I am not getting any faults. The screen shows that I turned the spindle on but shows no load.
    Jun 2005
    1561
    Re: Spindle won't turn on VM5020
    If your VFD has a speed knob you could change one parameter in the drive and see if it spins when using VFD panel interface
    Jan 2005
    14186
    Quote Originally Posted by bencody3001 View Post
    Check that all the I/0 relays are working it seems your ON /Off Relay is not working, or you have a broken wire
    Mactec54
  1. Replies: 14
    Last Post: 05-02-2022, 03:03 PM
  2. Spindle won't turn off
    By CarbonMan in forum Chinese Machines
    Last Post: 07-01-2020, 08:00 AM
  3. Spindle won't turn on
    By aksu74 in forum Tormach Personal CNC Mill
    Last Post: 04-22-2012, 12:26 PM
  4. Spindle won't turn on
    By ranchak in forum Bridgeport / Hardinge Mills
    Last Post: 08-30-2009, 12:32 AM
  5. interact 4 spindle drive won't turn on spindle
    By 0041601 in forum Bridgeport / Hardinge Mills
    Last Post: 06-23-2008, 11:51 PM
