For Ads/Sign workshop, DXF with splines and/or polylines are used usually, a large number of control points would be generated for cutting software and it's not kind to cnc cutting machine, so the dxf must be optimized when we importing it.
CutLeader would check the total geometry quantity of the dxf file, the optimization would be processed automatically when the quantity exceed a specific value.The number of the control points would be reduced dramatically bu the new optimized gemetry is within the specified tolerance still.
Before optimization, there are 744 short lines.
[ATTACH=CONFIG]422938[/ATTACH]
After optimization, there are 44 geometries only.
[ATTACH=CONFIG]422940[/ATTACH]
Here is the parameter for optimization.
[ATTACH=CONFIG]422936[/ATTACH]
