591,381 active members*
6,657 visitors online*
IndustryArena Forum > CAM Software > Vectric > Split SVG into multiple segments
    Good evening. My problem is I am trying to cut a file that is too large for my machine specifications.. I am trying to find an easy way to tile my cuts without having to do a lot of note editing. Any help would be appreciated.
    Jun 2015
    4178
    Re: Split SVG into multiple segments
    hello you could scan the program, an break it between rapid moves, thus where tool is not in contact, not feeding
    a secondary check, should verify if rapid ocurs at Z>0, etc
    i can build a software to scan your toolpath, and do the breaking
    next, a schedule function should come in handy, if available on your cnc, as to autoselect and run next program / kindly
  1. SVG to G-code converter
    By C_N_C in forum Uncategorised CAM Discussion
    Last Post: 09-12-2023, 03:05 PM
  2. 3 in 1 highchair dxf svg or eps
    By paulisa2 in forum USA Club House
    Last Post: 09-11-2017, 06:54 AM
  3. Convert jpeg to svg for MK3/4
    By wisconsinjimmy in forum USA Club House
    Last Post: 08-13-2017, 11:27 AM
  4. Inkscape .SVG to SolidWorks .DXF
    By BasuraBlanco in forum Solidworks
    Last Post: 08-07-2012, 04:21 PM
  5. svg to gcode?
    By b0j3 in forum OpenSource Software
    Last Post: 08-22-2007, 05:08 AM
