504,064 active members
5,722 visitors online
IndustryArena Forum > CAM Software > SprutCAM > SprutCAM 12 soon
Page 1 of 5 123
Results 1 to 12 of 53
    Feb 2008
    138
    SprutCAM 12 soon
    Hey guys have you had chance to look at whats changed in SC12? I got email with promo upgrade, looks like a number of changes are coming?
    I have not had time to watch all the video's yet, nor read up
    If you have read and watched what are you looking forward to? I have been quite happy with SC11.5
    https://www.youtube.com/playlist?lis...r7YEI82vIhgDgu
    Nov 2007
    1724
    Re: SprutCAM 12 soon
    I spent a little time reviewing sc12 help. The entire mill / lathe/ tool table system.... file... whatever.... imho needed a great deal of work and attention. Sadly looks to be the same.
    They added a plunge roughing operation. Looked useful, saves setup time for that type of strategy. I use that method a lot in the past and also found it worked my spindle bearings hard, so I don't always use the strategy. Still having a built in operation helps. They also talked about a new improved simulator. I like the old one just fine. The Interface is changing also, again I thought the old one was clean and ok to work with.
    Gold Member
    Jun 2006
    3021
    I'm hoping for general improvements in the UI, especially with machine setup but their YouTube videos haven't touched on that yet. Speaking of which, the quality of those videos seems to be improved over past efforst. Or maybe I'm just learning to think Russian.
    Feb 2008
    138
    SprutCAM 12 is expected to launch next month with final dates to be determined. Here’s what you can expect:
    New User Interface
    Visualization Improvements
    New 2D CAD integrated into Model Page
    PMI information import
    Painting Simulation
    3rd Party interpreters for G-code based simulation
    New high speed milling strategy: adaptive
    Plunge roughing
    from the email also link
    https://kb.sprutcam.com/SCmanual/lat...in-sprutcam-12
    I want more info on the supposedly new 2D? No video of it yet?
    New 2D CAD integrated into Model page
    New 2D CAD module is based on the new kernel.
    Advantages:
    parametric design. User can edit a model with saving selected objects properties or relations between them;
    model can be handled with any parameter because of independence of the model on sequence of objects creation.
    It is possible because we have implemented bidirectional associativity between model elements and parallel technology.
    Older SprutCAM versions projects will be converted automatically when loaded.
    To activate 2D CAD editor press "Sketch" button while being on Model page:
    Nov 2007
    1724
    Quote Originally Posted by MichaelHenry View Post
    UI does look simplified with most of the buttons wrapped around window frame. Hole capping option for use during job zone setup also looks very useful. I thought I was only person that was frustrated with how it picked up some features even when block or machined, causing extra movements. Maybe this will help with job zone limits and features it tries to mill. The cool thing about sprut is if auto 3d machine ops are not efficient you can always use 2d ops get it done.
    Wish my cad had full surface links like solid works has. That would be very handy. but I will get by
    I do a lot of 4th axis work these days. I hope the dialogs have not changed much for those ops. It took considerable time to learn what is what and what to set to get best 4axis results.
    They also note they are working to list this app so it works better with virus and fire walls.
    Feb 2008
    138
    actually had more time to watch few more videos the 2D I'm impressed by what they have now! also the fill option (hole cover) is going to be so useful! I do not have to go back and forth or load new specialized model to skip some sections that need to be machined later time
    https://www.youtube.com/watch?v=XbGNkgGpNRY
    https://www.youtube.com/watch?v=J_immP2OuXM
    Mar 2015
    150
    Got the email from Tormach and ordered the upgrade to v12 today....
    Hopefully the improvements are all that and its stable.
    Gold Member
    Jun 2006
    3021
    I got the email today, too, and placed an order for an "All Posts" version. I may be picking up a Pocket NC 5-axis table top mill to play around with and correspondence with Sprut a few months ago suggested that they had at least some sort of post support for that machine.
    Mar 2015
    150
    I forget, does the upgrade come via internet download or an actual CD with new new usb dongle in the mail?
    Feb 2008
    138
    Quote Originally Posted by Paul-JB View Post
    I believe they send you the cd still( or I might forget, might be download now from last SC upgrade)? but been using same dongle, I think they upgrade the dongle with some of the files on cd on first install? or something to that effect, also it could be done with the online sign in, on SC but mine is the regular SprutCAM America version, not the Tormach one.
    Gold Member
    Jun 2006
    3021
    According to the email I got today, it looks like it is an installable download along with a license file and uses the old SC11 dongle, possibly earlier dongles as well.
    It will be a few days before I install as there are some pending jobs that must be done first.
    Mar 2015
    150
    I installed it tonight. Played around for like 5 minutes before swmbo called me up for dinner. Soon as I get back from nightly dog walk I’m going back down and checking it out some more.
    Downloaded it off the sprutcam website and went with the online installer route. Put the activation code they emailed me in using license manager which by the way is now accessible by right clicking on the sprut logo. In 11 the license manager was under the help dropdown.
Page 1 of 5 123
  1. Sprutcam 9
    By Michigan Ed in forum SprutCAM
    Last Post: 12-11-2015, 02:56 PM
  2. Transition from no Sprutcam to Sprutcam-9
    By Uman in forum SprutCAM
    Last Post: 06-09-2015, 12:58 PM
  3. do I need sprutcam?
    By grebber in forum Tormach Personal CNC Mill
    Last Post: 04-03-2015, 01:09 PM
  4. Sprutcam 8
    By scottsss in forum SprutCAM
    Last Post: 10-26-2012, 04:06 AM
  5. SprutCam
    By ErnieD in forum Tormach Personal CNC Mill
    Last Post: 09-10-2009, 08:24 PM
