589,390 active members*
7,427 visitors online*
IndustryArena Forum > Material Technology > Metallurgy > Stainless Steel Wedge Wire Screen Tube
Results 1 to 1 of 1
    Jun 2024
    4
    Wedge wire screen tube is made of welding V-shaped profile wire by Wrapping Cylindrically around support rods under automatic specialized wedge wire screen machine. Each profile wire and support rod is contacted by resistance welding. Support wire can be inside or outside according to flow direction ,wedge wire screen tube’s slot range from 0.2 to 5mm.
    Wedge Wire Screen Tube Material
    When select stainless steel grade that must endure corrosive environments, austenitic stainless steels are typically used. The most common types of stainless steel for welded wire screen are grades 304 304L 316 316L.
    Wedge Wire Screen Tube Specifications
    Slot size: 0.2 mm to 5 mm
    Pipe diameter : 25 mm to 2500 mm
    Pipe length : up to 12 m
    For more details,please email us.
    Wedge Wire Screen Tube End Types
    Wedge wire screen tubes have different edge types to suit different applications, which includes,but not limit to the following
    Common type
    Ring type
    Threaded type
    Flange type
    Wedge Wire Screen Tube Application
    Power plants
    Fish hatcheries &Desalination plants
    Firefighting &Drainage channels
    Potable water and Drinking water plants
    Desalination plants
    Water intake &water treatment
    Separating,Filtering,Drying
    Oil-water separation
    sugar process &rotating pulping
    water well production,
    food and beverage,
    oil and gas,
    pulp and paper,
    mineral and aggregate processing,
    refining and petrochemical.
    Benefits
    V type wire, no plugged
    No move part, simple to install
    Low maintenance costs
    Economical and applicable type, long life
    Cost effective
    High precision sizes
    High mechanical strength, lightweight construction
    Excellent filtration performance
    Minimizes clogging
    Maximum flow rates
    Resistant to temperature variations
    For more details,please contact us
    Julia
    Web Wire Mesh CO.,LTD
    Tel: +86031189255081
    +8603187568801
    http://www.webwirecloth.com
    Email: [email protected]
    Address:East Zone of Industry Park,Hebei,China
    Attached Thumbnails Attached Thumbnails src=http-%2F%2Fimg.alicdn.com%2Fimgextra%2Fi2%2F6000000004226%2FO1CN016fcqnI1h5YSAu2QMq_!!600000.jpg   Heb8b857850e043e99d1f8e677b8fe7ffp.jpg_960x960.jpg   u=2699816432,2853771149&fm=199&app=68&f=JPEG.jpg   O1CN01y8Ixyl2DCwZnd3Lfe_!!2211641728574-0-cib.jpg
    bnu_6XsWMR6MBdAT3nW-pRACIP8.jpg   O1CN01viwx211EuHXmuHDGS_!!2214143420411-0-cib.jpg   Stainless-Steel-Screen.jpg   screen1.jpg
