Hello
I have a problem. I lost my all parameters from machine. Machine is empty. Im lost ladder and other parameters. Maybe there is a person who has such a machine and can download the parameters from the machine to me?
Hello
What makes you think that the ladder is gone? The (nc and pmc) parameters I understand, but not the ladder or system files.
I have problem and alarm with RAM parity. Then I reset memory, then i lost parameters and lost ladder. Earlier I had a problem with a computer that was being repaired, possibly it was the cause.
I have parameters files to backup and got ladder files from factory. How to upload ladder to the ROM? Which files are from ladder?
Hello:
You don´t need to upload the ladder. Once you reset the machine, (clear memory) you should see many alarmas indicating you lost all parameters. Why would you enter the Boot system (System check screen)? Do not do anything in there.
The ladder should appear as soon as you enter all Nc parameters.
Regards
AlexFanuc
This number is on main board: FANUC 16MB A02B-0200-B503 / MAIN FS16B , CPU board number is A16b 3200 0010/07A
Post all of the M5301159.#xx files. I can convert these files to a MEM file that you will be able to load into your machine.
First I will install the parameters files, and when the ladder is gone it will load ladder file.
You have to copy it onto a Flash card and load it in that way. The file is here ready to load. It's called PMC-RC.000. The controller doesn't care what the file name is as long as it's a ladder file. You load it BOOT mode under System Data Load. (I added it to your rar file).
Hello
I load the PMC-RC file into the ROM on the machine.
I can see the LADDER in the machineyeah
I have a problem. I have two alarms:
-ER07 NO LADDER STEPS OPTION
-WN17 NO OPTION (LANGUAGE)
I think this problem is because I don't have PMC parameters loaded on my computer. How can I load these parameters to the machine from my memory card? I have four files from the factory (attached). What extension should the files have?
I'm having trouble loading files from my PC because I can't select EDIT mode on my computer.
Loading system files and parameters should be done in MDI mode (default) and E-stop condition.
I didn't see any CNC Parameters among these files. Did you load these? The errors that you are getting are related to option parameters not set to support that ladder that you installed. 9900's parameters is where these are stored. ALL CNC parameters must be loaded first.
