547,049 active members*
1,625 visitors online*
Thread: Star points
Results 1 to 5 of 5
    Oct 2020
    6
    Star points
    What are some good settings to get a good crisp star point. Each of my tips are kinda rounded not pointed
    Sent from my SM-G781U using Tapatalk
    Jan 2018
    942
    Re: Star points
    Quote Originally Posted by jpmreno View Post
    Hi matey.
    May want to re-word your title to be a bit more specific to your needs..
    Most people (whom you may need) will think you're asking about grounding and go straight past this.
    Most call the point of grounding for shielding of cables etc their 'star point'.
    Oct 2020
    6
    Re: Star points
    I'm sorry I'm talking about getting crisp points on stars with a cnc router. My bad sorry about that.
    Community Moderator difalkner's Avatar
    Nov 2014
    705
    Re: Star points
    Inside or outside points? Outside are easy, inside you'll have to use a V-bit.
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Mar 2008
    619
    Re: Star points
    Which CNC package are you using. There are a few setting to use for sharp points. One that may be rounding your corners is "roll around corners." Turn that off and use straight corners or "D" corners.
  1. Replies: 1
    Last Post: 05-11-2021, 09:56 AM
  2. Star PU JR. Software Program Utility
    By cosmo2000 in forum CNC Swiss Screw Machines
    Last Post: 03-15-2018, 07:33 PM
  3. Zero points
    By Hunterkoile in forum Hypermill
    Last Post: 08-17-2009, 08:34 AM
  4. POINTS
    By el gordo in forum Mastercam
    Last Post: 10-05-2008, 04:41 AM
  5. Points on arcs
    By gguidi in forum Autodesk
    Last Post: 07-25-2006, 01:49 PM
