544,218 active members*
3,009 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > starting my C program, any guidance would be appreciated.
Page 1 of 11 123
Results 1 to 20 of 208
    I have my initialization C program, after tuning the servos, for my axis done. Is defining each of the I/O all I need to in order to run G code?
    Junior Member
    May 2006
    3775
    Re: starting my C program, any guidance would be apreciated.
    Hi Gunmachinist,
    I'm not sure what you mean by: "defining each of the I/O"
    It depends on what devices you have in your system and how are they controlled.
    Normally to run KMotionCNC you would assign a User INIT button to the initialization C Program.
    Then configure all your MCodes.
    Then configure all of the Trajectory Planner Settings. See here and here.
    HTH
    TK
    http://dynomotion.com
    Thinking I would need to add my limit switch I/O to my ini. C program for them to work.
    Like:
    int LimitSwitchNegBit; // Neg Limit I/O Bit number
    int LimitSwitchPosBit; // Pos Limit I/O Bit number
    Junior Member
    May 2006
    3775
    Configure them using the Configuration Screen as described here.
    The export to your C Program as described here.
    TK
    I have been working with KMotionCNC in the Tool Setup Screen (M0 - M30). I've been able to get the spendle working CW/CCW/stop but am having trouble with how to get my axis working while running g code. My init. C program was done but the axis and most g-code telling the axis to m ove will not work, what am I missing?
    Junior Member
    May 2006
    3775
    How have you configured M0-M30 ?
    What is the GCode that doesn't work?
    Post your Init Program.
    TK
    just started attempting to get this mill working but, here is a few screen shots of what I have at this point. I don't understand what the key box is on the User Button page. I know I need to create some C code for the rest of the M codes, or is there a place I can locate existing c code for them?
    Junior Member
    May 2006
    3775
    The Key box is for specifying a keyboard shortcut key for the button. See here.
    It seems your INIT C Program isn't enabling the axes. Is it? See here.
    Nothing is configured for the S Action. Do you want to use it to control the Spindle Speed? See here.
    TK
    here is my init file. I'm also having a problem with my limit switch, when they are active my axis will not move unless I manually press the switch.
    Attached Files Attached Files
    Junior Member
    May 2006
    3775
    You can change the polarity of limit switches by changing the "Stop when Low" Limit Switch Option as described here.
    TK
    Quote Originally Posted by TomKerekes View Post
    int -EnableAxis(0);
    int -EnableAxis(1);
    int -EnableAxis(2);
    int -EnableAxisDest(Z,0);
    int -EnableAxisDest(Y,1);
    int -EnableAxisDest(X,2);
    DefineCoordSystem(0,1,2,-1);
    Not sure how to get it to work, is this headed in the correct direction? If not then how?
    Junior Member
    May 2006
    3775
    No that's wrong. The code you posted after I asked was correct. Does it enable the axes?
    TK
    No. It does not and keeps giving me the error pop up I posted in the screen shot.
    I have gotten the X and Y axis moving, but when the X axis moves it counts in the screen Z axis. X axis will count like its moving but nothing moves. How do I correct the X axis to make it the X axis?
    Junior Member
    May 2006
    3775
    Which axes in KFLOP are your X and Z axes?
    TK
    This what you mean:
    0=Z
    1=Y
    2=Z
  17. #17
    Junior Member
    May 2006
    3775
    Is that a typo?
    TK
  18. #18
    Is that a typo?
    Thats where the axis are connected in Kanalog, which is where I have everything connected. Maybe I missed a step where I specified that 0=Z, and 2=X ang just got lucky with Y=1?
  19. #19
    Junior Member
    May 2006
    3775
    So you did make a mistake in the previous post? Then code:
    DefineCoordSystem(2,1,0,-1); // define XYZA axes
    instead of
    TK
  20. #20
    instead of
    That helped get X and Y working correctly, but Z still doesn work. I also tried [DefineCoordSystem(2,1,-1,0); // define XYZA axes] without success. How are the axis supposed to be defined normally?
Page 1 of 11 123
  1. Starting at New CNC Build -- Guidance Needed!!
    By dtmille2 in forum DIY CNC Router Table Machines
    Last Post: 01-02-2013, 05:00 AM
  2. Need some guidance on starting out
    By AlanDv in forum DIY CNC Router Table Machines
    Last Post: 08-20-2011, 05:13 AM
  3. starting program
    By chucker in forum Fanuc
    Last Post: 11-10-2009, 07:28 PM
  4. Starting program in fanuc 6m
    By Bolle_Ma in forum Fanuc
    Last Post: 10-17-2008, 09:11 AM
  5. Starting knee-mill retrofit. Your input appreciated.
    By jamma in forum Uncategorised MetalWorking Machines
    Last Post: 03-01-2007, 05:41 PM
