531,637 active members*
3,791 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > starting my C program, any guidance would be apreciated.
Results 1 to 4 of 4
    I have my initialization C program, after tuning the servos, for my axis done. Is defining each of the I/O all I need to in order to run G code?
    Junior Member
    May 2006
    3545
    Re: starting my C program, any guidance would be apreciated.
    Hi Gunmachinist,
    I'm not sure what you mean by: "defining each of the I/O"
    It depends on what devices you have in your system and how are they controlled.
    Normally to run KMotionCNC you would assign a User INIT button to the initialization C Program.
    Then configure all your MCodes.
    Then configure all of the Trajectory Planner Settings. See here and here.
    HTH
    TK
    http://dynomotion.com
    Thinking I would need to add my limit switch I/O to my ini. C program for them to work.
    Like:
    int LimitSwitchNegBit; // Neg Limit I/O Bit number
    int LimitSwitchPosBit; // Pos Limit I/O Bit number
    Junior Member
    May 2006
    3545
    Configure them using the Configuration Screen as described here.
    The export to your C Program as described here.
    TK
  1. Mini mill conversion Input apreciated
    By crl1_1 in forum Benchtop Machines
    Last Post: 07-27-2018, 07:14 AM
  2. Starting mid program... can it be done?
    By Brian L in forum Milltronics
    Last Post: 07-10-2014, 02:55 PM
  3. Starting at New CNC Build -- Guidance Needed!!
    By dtmille2 in forum DIY CNC Router Table Machines
    Last Post: 01-02-2013, 05:00 AM
  4. Need some guidance on starting out
    By AlanDv in forum DIY CNC Router Table Machines
    Last Post: 08-20-2011, 05:13 AM
  5. starting program
    By chucker in forum Fanuc
    Last Post: 11-10-2009, 07:28 PM
