554,132 active members*
3,747 visitors online*
    Nov 2021
    19
    Steel frame/gantry design..
    Doing up a dedicated skateboard cnc. This one will get a 2.2kw spindle and a .6kw.
    The primary spindle will profile the deck, secondary will drill truck mount holes. The last build only did popsicle sized decks, this one will cut up to a 44" x 12" longboard. Any constructive comments?
    Apr 2004
    5539
    Re: Steel frame/gantry design..
    Have you tried mounting anything to those trucks and seeing how well it slides? Hot-rolled steel (even before it's welded) is not usually flat enough to mount profile rails to directly without modification, although some are more forgiving than others. What did you do to ensure that both of the rails of each axis are in the same plane?
    Andrew Werby
    Website
    Nov 2021
    19
    If you are referring to the gantry trucks, yes.
    I used a 1/4" plate with 4 trucks mounted to it to align the beams while welding. I have a flat welding table with dog holes in it that accompany clamps and dogs that help keep things square.. With a little technique it isn't to hard to keep things straight. Again this makes skateboards only. If the rails run smoothly we are good. And yes on checking each axis being on the same plane. I wouldn't make any airplane parts on it but it will knock out skateboards all day..This is a low dollar unit. I have made a unit with an extruded frame over a steel frame. This unit will fill the bill...
  1. Building Steel Frame Gantry Router for wood, MDF, and maybe more
    By thegadgetguy in forum DIY CNC Router Table Machines
    Last Post: 12-18-2021, 01:44 AM
  2. 4' x 4' x 9" Welded Steel Frame Fixed Gantry CNC Router
    By Dillsnap759 in forum CNC Wood Router Project Log
    Last Post: 12-02-2020, 10:06 PM
  3. help me to design steel frame for my 10' X 5' CNC router
    By palyoK in forum DIY CNC Router Table Machines
    Last Post: 11-20-2018, 02:35 PM
  4. first build, frame ready, opinions of my solidworks gantry design needed
    By Rory1369 in forum DIY CNC Router Table Machines
    Last Post: 04-10-2016, 12:56 AM
  5. steel frame gantry flex
    By wentyfalls in forum CNC Wood Router Project Log
    Last Post: 07-04-2013, 05:37 PM
