585,996 active members*
4,497 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Step direction voltage not changing
Results 1 to 5 of 5
    Apr 2020
    14
    Hi gang,
    I have a homebuilt cnc router (PrintNC) that uses a UC300ETH controller with a C77 driver terminal board and UCCNC software. I started having intermittent problems with the X axis only moving in one direction and would eventually self correct. Well today it won't. With some searching here in the site, I eliminated loose connections, malfunctioning driver,keyboard, etc. When I checked the voltage for the direction terminals I get 4.7 and 0 for all the drives except the X. It stays at 4.7v despite inputting a direction change. Does this signify a bad controller or would it possibly the attached terminal board? Any thoughts or suggestions are greatly appreciated.
    Mike
    Jan 2018
    1516
    Re: Step direction voltage not changing
    Quote Originally Posted by mchesney1 View Post
    Mike
    The C77 looks to me to have isolated outputs.
    That tells me that it is an issue with one of the optocouplers on the C77 itself.
    Any chance you could change things round and assign axis 5 or 6 to work as X instead?.
    https://www.cnc4pc.com/pub/media/pro...7rev1.5_v2.pdf
    Apr 2020
    14
    Will try that today. Thanks for the response!
    Apr 2020
    14
    Quote Originally Posted by dazp1976 View Post
    That worked! Thanks for the help, it is very appreciated!
    Jan 2018
    1516
    Excellent. Good to hear your working again.
    Daz.
  1. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  2. Replies: 4
    Last Post: 09-10-2013, 04:52 AM
  3. Direction keeps changing
    By jjacstcy in forum DIY CNC Router Table Machines
    Last Post: 05-07-2011, 09:06 PM
  4. Step/Direction pins should be Step FWD and Step BACK
    By rayscott in forum Mach Software (ArtSoft software)
    Last Post: 02-10-2010, 12:57 AM
  5. Changing of cutting direction
    By wurst17 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-07-2008, 04:13 PM
