585,997 active members*
5,068 visitors online*
    Apr 2016
    4
    stepcraft grbl setup
    I have bee using my Stepcraft for a few months and all is working well. I had it paired with Estlcam but now I would like to move to Fusion 360 and use Grbl. I have done all the installing and it is operational. I am unsure how to calibrate the settings and I would like some help. This picture displays the current settings I use with Estlcam (and the only settings I know) Imgur: The most awesome images on the Internet
    I am unsure how these translate to the Grbl settings
    Code:
    $0 = 10    (Step pulse time, microseconds)
    Code:
    $1 = 25    (Step idle delay, milliseconds)
    $2 = 0    (Step pulse invert, mask)
    $3 = 0    (Step direction invert, mask)
    $4 = 0    (Invert step enable pin, boolean)
    $5 = 0    (Invert limit pins, boolean)
    $6 = 0    (Invert probe pin, boolean)
    $10 = 1    (Status report options, mask)
    $11 = 0.010    (Junction deviation, millimeters)
    $12 = 0.002    (Arc tolerance, millimeters)
    $13 = 0    (Report in inches, boolean)
    $20 = 0    (Soft limits enable, boolean)
    $21 = 0    (Hard limits enable, boolean)
    $22 = 0    (Homing cycle enable, boolean)
    $23 = 0    (Homing direction invert, mask)
    $24 = 25.000    (Homing locate feed rate, mm/min)
    $25 = 500.000    (Homing search seek rate, mm/min)
    $26 = 250    (Homing switch debounce delay, milliseconds)
    $27 = 1.000    (Homing switch pull-off distance, millimeters)
    $30 = 1000    (Maximum spindle speed, RPM)
    $31 = 0    (Minimum spindle speed, RPM)
    $32 = 0    (Laser-mode enable, boolean)
    $100 = 250.000    (X-axis travel resolution, step/mm)
    $101 = 250.000    (Y-axis travel resolution, step/mm)
    $102 = 250.000    (Z-axis travel resolution, step/mm)
    $110 = 500.000    (X-axis maximum rate, mm/min)
    $111 = 500.000    (Y-axis maximum rate, mm/min)
    $112 = 500.000    (Z-axis maximum rate, mm/min)
    $120 = 10.000    (X-axis acceleration, mm/sec^2)
    $121 = 10.000    (Y-axis acceleration, mm/sec^2)
    $122 = 10.000    (Z-axis acceleration, mm/sec^2)
    $130 = 200.000    (X-axis maximum travel, millimeters)
    $131 = 200.000    (Y-axis maximum travel, millimeters)
    $132 = 200.000    (Z-axis maximum travel, millimeters)
    Apr 2016
    4
    Re: stepcraft grbl setup
    I have this if it helps. The official profile of the machine.
    https://www.stepcraft-systems.com/im...s-20161119.pdf
  1. Help configuring GRBL Settings in new Setup
    By dregalia in forum Arduino
    Last Post: 12-19-2017, 04:27 PM
  2. Replies: 1
    Last Post: 08-19-2016, 11:57 AM
  3. Stepcraft Choice
    By rusty999 in forum Stepcraft
    Last Post: 03-13-2016, 11:31 PM
  4. X6-1500GT or Stepcraft v2 600
    By hayderOICO in forum Want To Buy...Need help!
    Last Post: 06-05-2015, 05:03 PM
  5. Kit cnc portique Stepcraft 600
    By elieheloua in forum French
    Last Post: 04-18-2015, 01:43 AM
