589,390 active members*
7,631 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Stepper motor controller+driver SMC02
    Hello, maybe some one can tell me , how can i connect a foot pedal swich , to the SMC02 controller, so i can control the stepper motor rotation CW and CCW by foot??
    Nov 2013
    4674
    Re: Stepper motor controller+driver SMC02
    If you reverse the polarity of either one of the two windings of a twp phase stepper you will reverse its rotation.
    All you require is a double throw-double pole switch in the pair of leads to one winding.
    Craig
    Mar 2004
    414
    >>> If you reverse the polarity of either one.....
    Ya, but..... A lot of motor drivers are not going to like that, meaning you could burn them up in a hurry. I dont think many people are familiar with your pulse generator (SMC02), so you might have to crack one open and look at the wiring to the CW/CCW buttons on the front panel. Hopefully you could parallel into them. I'd guess because they have two separate buttons for the function, you might need to parallel in two similar momentary switches in a foot pedal. I dont think it will be a situation where polarity is changed.
    I have used quite a few of the DKC-1A units (similar unit to yours on Amazon) for interesting projects. The DKC-1A does use a simple non momentary for direction change if by chance you want to try a different pulse generator.
    Chris L
  1. Chinese Stepper Driver - ZK-SMC02
    By MakingGears in forum Stepper Motors / Drives
    Last Post: 08-02-2023, 02:16 AM
  2. Stepper motor controller - driver
    By zeuszone in forum Stepper Motors / Drives
    Last Post: 08-10-2020, 07:04 AM
  3. Troubleshooting stepper motor, driver, and ub1 controller.
    By wallskm in forum UCCNC Control Software
    Last Post: 04-15-2019, 08:27 PM
  4. Mini-tech 2 and Stepper Motor Driver Controller?
    By art4x4 in forum Stepper Motors / Drives
    Last Post: 05-20-2011, 05:38 PM
  5. Cheap stepper motor controller and driver
    By webbyguy in forum Stepper Motors / Drives
    Last Post: 08-18-2010, 07:20 AM
