601,654 active members*
2,595 visitors online*
Results 1 to 1 of 1
    Apr 2025
    Stepper motor not turning
    bought small 4th axis
    worked once ,
    turn on its own while carving program not called to do , turn at different times and turn back on the same line !
    thought to small of a stepper motor.
    bought larger
    motor will not turn
    plug in new stepper motor ... did not turn.
    returned driver 2 times .
    unplug and plug in to driver for " Z " used the settings that set up for Z ...it turned !
    New motor is just setting there NOT connected to anything .
    The driver is for a simply stepper motor , all connections are check many times , math is right .
    it is 1.8 degrees so 200*16*1/360 = 8.88888 . The Z is set at 8165 plus ! On the steps per unit .
    The motor should turn .
    It is warming up a little. Current is set right 2.8 for a 3 amp stepper . Dip switch is set for full (90%)
    The read out is showing it is turning .
    Using UCCNC software
    DM542T driver
    UC400ET to my computer
    4 axis braker board.
    signal is getting to lap top , the read out is moving when axis is clicked .
    Why is it NOT turning ?
    Apr 2004
    5842
    Re: Stepper motor not turning
    It could be a bad cable.
    Andrew Werby
    Website
