547,633 active members*
3,558 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Stepper Motor Power Supply Size?? Calculator??
Results 1 to 5 of 5
    Neuer Benutzer
    Feb 2013
    17
    Hello, I am rebuilding an older CNC with slo-syn stepper motors. The specs for the motor are:
    200 Steps per revolution
    Holding Torque = 770
    Voltage = 1.4
    Phase Resistance = .200
    Current = 7.0
    Phase Inductance = 1.49
    I have Gecko GR214V 7AMP drivers powered by a 48V power supply. The motors will heat up within 10 minutes of just sitting there, where I can not even touch them. I am concerned that they have told me to get the wrong power supply. I am new to this, so please bear with me. Is there a calculator to figure out what the correct power supply voltage should be? Or does anyone no what I should be using. I have a feeling this is too much voltage. Thanks!
    Nov 2012
    1134
    Re: Stepper Motor Power Supply Size?? Calculator??
    Quote Originally Posted by tnwalkinghorse View Post
    Stepper motors will heat up even "just sitting there", that's normal. And they do get pretty hot, that's normal too. If they get TOO hot, you can always lower the motor current using the DIP switches inside the Gecko.
    The higher the better (within the driver's capability, which is 80V max for your Gecko). Higher voltage allows you to spin the stepper motor faster without stalling. Which means higher feed speeds and shorter machining times.
    Neuer Benutzer
    Feb 2013
    17
    I also have a Shop Bot and can run a 4 hour job and the motor will barely go above room temperature. This is why I am concerned. It smells like burning wires and heats up way to fast. I lowered the motor voltage from 48v to 39v last night and did notice a slight improvement. The motor is constantly buzzing also. Should I lower the current to 6 amps? Thanks!
    Nov 2012
    1134
    That means the motor current was set conservatively; you can safely increase it if you ever need to.
    The smell of burning wires is definitely not good, you should lower the current until the motors assume more comfortable temperature. Leave the power supply voltage at 48V, you don't need to change it to control the current.
    Like Citizen said, it's the current you are concerned about. For nearly all operation the stepper heat is resistive losses, I^2*R. No voltage component.
  1. Free stepper/servo motor size calculator!
    By jeffs555 in forum DIY CNC Router Table Machines
    Last Post: 10-11-2013, 08:28 PM
  2. Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2011, 12:50 PM
  3. Power supply size ??? for Stepper Motors
    By wdysf150 in forum DIY CNC Router Table Machines
    Last Post: 01-19-2009, 08:23 AM
  4. Power supply for stepper motor
    By gaga2410 in forum Stepper Motors / Drives
    Last Post: 11-09-2007, 12:42 AM
  5. help on stepper motor power supply
    By ahmed in forum Stepper Motors / Drives
    Last Post: 06-14-2005, 05:56 PM
