549,843 active members*
3,156 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Steppers making noise but not spinning my lathe chuck...any advice?
Results 1 to 13 of 13
    Aug 2019
    Red face Steppers making noise but not spinning my lathe chuck...any advice?
    Hi. I am making a lathe to use with glass. These require head and tail stock to turn in unison and they are VERY expensive so Im making my own.
    Could use advice on my new setup.
    I know the wiring is correct and when I turn the dial it whirls faster and slower but doesnt turn the shaft. Here are my specs. Any advice?
    NEW SPEED CONTROLLER
    Input: DC 7.5-24V
    +24V input
    +5V output
    NEW SWITCHING POWER SUPPLY
    24V
    5A
    NEW CONTROLLER
    Output current: 0.5A-4.0A
    Input Voltage: 9-42VDC
    NEW STEPPER MOTOR WITH LATHE CHUCK
    2phase nema23 stepper motor
    4.2V
    3 A
    Dec 2013
    5242
    Re: Steppers making noise but not spinning my lathe chuck...any advice?
    By ''whirls'' do you mean the motor is making noise but the shaft is not turning?
    Post links to your hardware. Maybe some pictures of your setup.
    Normally glass lathes have a splined shaft drive between the headstock and tailstock.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2019
    Quote Originally Posted by Jim Dawson View Post
    Yes, its off the lathe right now. It makes a whirling sound when I turn up the speed controller ...goes into a higher pitch as I turn it up. But it vibrates and the shaft wiggles back and forth but no spinning. I am including the wiring diagram I used for the speed controller. I can crank the pulley by hand no problem.
    Dec 2013
    5242
    Are your Pulse & Direction signals reversed by chance?
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2019
    Wires double checked ok..
    I put my multimeter in line with the + lead that goes into the motor and it only read 0.10 amps. This seems like the problem yes? (I ordered a cheap power supply from ebay)
    Dec 2021
    Hi guys,
    I am using Long Path Tool. you can try also. It very easy to use.
    Thanks!
    Dec 2013
    5242
    I don't think a multimeter would tell you much. Which + lead? There are two, A+ and B+
    Is the power supply maintaining 24V output when the motor is trying to run?
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2012
    1170
    Make sure your motor windings are connected correctly (one winding between A+ and A-, the other one between B+ and B-).
    You can also disconnect the DIR signal temporarily, just in case there is something funny going on with your speed controller.
    Aug 2019
    The As and Bs are paired and installed correctly and the supply puts out a constant 24V. Should I be paying attention to the controller dip switches? Thanks
    Dec 2013
    5242
    Quote Originally Posted by Foiler View Post
    I would start by setting the DIP switches to 1/2 step and motor rated amps.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2012
    1170
    You definitely should, although you should see some kind of rotation with pretty much any switch settings. Set the current to 3A and the microstepping to 1:8 for starters.
    Does the motor lock up (gets hard to turn by hand) when the power is on?
    Does the speed controller have any switches or menu settings?
    Have you tried disconnecting the DIR signal?
    Aug 2019
    Quote Originally Posted by CitizenOfDreams View Post
    I got it...I was reading the continuity option on my multimeter wrong and the motor wiring pairs were off....DUH.....persistence pays
    Thanks for the replies folks. Stay healthy.
    Nov 2012
    1170
    Glad you got it solved! If I may ask, what kind of glassware are planning to make with your new lathe?
    Aug 2019
    Cool Re: Steppers making noise but not spinning my lathe chuck...any advice?
    Hi. I am working with scientific glass operations, flasks and tube inserts that sort of thing. Here is a pic of my lathe so far. Both the head and tail need to turn in unison.
    You cant get one of these for under $5k....at the very least...its rather ridiculous. I am converting an old wood lathe I got from a garage sale. You can see I am also using some cross slides
    I also picked up for a few bucks at garage sales to allow me to line things up properly. The stand is from a harbor freight metal brake I never use.
  1. Chuck Not Releasing after spinning...
    By BDompierre in forum Multicam Machines
    Last Post: 05-29-2020, 01:56 PM
  2. Replies: 4
    Last Post: 02-15-2018, 02:11 AM
  3. Spinning lathe application
    By xjdubber in forum Mach Software (ArtSoft software)
    Last Post: 10-29-2013, 05:28 PM
  4. Z-Axis making noise
    By 2Bits in forum Linear and Rotary Motion
    Last Post: 06-14-2011, 02:15 AM
  5. motor making noise
    By kasari in forum General CNC Machine Related Electronics
    Last Post: 01-17-2010, 01:33 AM
