In my free time, I have been playing around with a dead simple EDM power supply design. I had some IRF610's (200V, 3.3A) laying around so I paralled 6 of them for my intended 15A max current. All the drains and sources are connected directly. Each gate is joined to a common point through a 100 ohm gate resistor. The drains are connected to the "workpiece", source runs through a .1 ohm shunt resistor and then to ground. The "electrode" is connected to +63V on my linear power supply.
I am using a comparator to disable my gate driver at the desired current threshold. I am driving the gate driver with a function generator, set at 1kHz 50% duty square wave. I am monitoring the gate drive signal with a scope and it seems to work properly. The current limiting is running at something like 10-20 kHz while my square wave is high.
I tested the circuit using an LED and resistor between electrode and workpiece and it worked properly (turning on and off). Then I decided to raise the bets and try a real spark. I used a 23 ohm resistor in series to protect the circuit in case my current limiting didn't work. After I "sparked" the electrode with the workpiece (just wires at this point in the game) it appears that I have killed my MOSFET's. They will not turn off now.
I think this may be dv/dt related? I think it cannot be due to current because the series resistor limits the current to under 3 amps, less than the rating of a single MOSFET, let alone the 6 in parallel I have.
Anyone have any great ideas?
Matt
