504,413 active members
5,059 visitors online
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Stripped the column cap head screws on g0704
Page 1 of 3 123
Results 1 to 12 of 26
    Oct 2017
    17
    I managed to over tighten and strip the screws that attach the column to the base on my g0704.
    They are m12 cap head screws near the base there are 4 of them. Is it even possible to extract these?
    I stripped two of them like an idiot.
    Re: Stripped the column cap head screws on g0704
    Did you actually strip the threads or the socket head?
    If the socket head, you can drill the heads off. Just drill with a body sized drill bit until the head pops off. Slow speed and a lot of pressure, these are hard bolts. Then remove the column and remove the rest of the screw, or maybe you can screw it out with a pair of needle nose pliers
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2017
    17
    Quote Originally Posted by Jim Dawson View Post
    Yeah the socket head I meant. So if I drilled the head of the socket head cap screw...it will just pop off? Is the head the only part holding the column against the base?
    Thank you for such a quick reply.
    I was thinking of using a hex bit driver and jbweld it and leave it 24 hour over night
    Quote Originally Posted by addman16 View Post
    That's pretty much the way a bolt works
    My pleasure
    That might work also.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2003
    338
    Once you have taken off the head of the last bolts what might happen to the part that is freed?Consider very carefully the possibility that a large and heavy piece of machinery might land on your head.
    Jan 2018
    287
    Wouldn't fancy drilling it myself.
    I'd see if I could knock an imperial size bit in the bolt heads if the heads are metric.
    Or I'd grind a slot across the bolt head and use something with a flat end to screw it off.
    Jan 2005
    1938
    Go buy a screw extractor set. They make them for SHCS.
    https://www.amazon.com/Irwin-Tools-5...24363678&psc=1
    The Imperial to metric method works. Assuming there is a slightly large Imperial size, just hammer it in and then turn.
    Or you can grind a slightly large allen to a hexagonal taper, hammer it in, and then turn. That has worked very well for me.
    I've also had good luck with left handed drill bits, you start drilling, pretty often the drill bit will grab and turn the bolt. If it does't grab, you just drill the head off.
    Feb 2019
    16
    If you can find a star bit of the right size which is a tight fit, it'll take the screw out. I remember reading somewhere a long time ago that hex bolts are engineered to strip out before any permanent damage should occur.
    Oct 2017
    17
    To be honest, Im a bit scared to drill the head off, considering that the bolt is under lots of tension, wouldnt the head fly off if I drill it off?
    No. The head would be captured by the drill bit, but it wont release with any appreciable force. You've never drilled the head off a bolt, obviously, nothing wrong with that though. All of the recommendations here are totally reasonable and safe. Pick one that suits you and go for it.
    Nov 2012
    742
    If you have enough room to work, the easiest way would be cutting a screwdriver slot in the bolt cap with a small angle grinder.
Page 1 of 3 123
  1. Had a weird problem pop up after replacing my column on G0704
    By skyguynca in forum Benchtop Machines
    Last Post: 12-14-2017, 06:52 PM
  2. G0704, Too tight Column Bolts
    By rrangana in forum Benchtop Machines
    Last Post: 05-26-2014, 12:01 AM
  3. WTB: Used Square Column Mill Washington / Oregon G0704, PM25MV, or PM30MV!
    By Contract_Pilot in forum Want To Buy...Need help!
    Last Post: 01-18-2014, 06:21 PM
  4. G0704 column bolts?
    By exitium in forum Benchtop Machines
    Last Post: 03-04-2013, 01:35 AM
  5. Column gibb is binding on g0704
    By Nada mucho in forum Benchtop Machines
    Last Post: 02-02-2012, 01:27 PM
