504,132 active members
4,528 visitors online
IndustryArena Forum > CAD Software > Autodesk > Stupid Question - How to center objects on top of each other
Results 1 to 4 of 4
    Dec 2018
    This is going to seem like a stupid question I'm sure, but I've tried to watch videos and everything and just can't seem to find the answer to this. I'm trying to put together a model for a base plate for a camcorder to attach to a bracket that I already have. It will consist of 3 rectangles of decreasing size, with a threaded hole on the bottom and a stud on top.
    I've mocked it up in Photoshop (because that I actually understand how to use), but I just can't get the blocks to anchor themselves to the center point of the shape below in fusion.
    This is my first foray into 3d modelling, so be gentle. Was thinking of rounding the corners of the various bits as well. not sure how much work that would be to do.
    Anyway, any help would be appreciated.
    Mar 2003
    34502
    Re: Stupid Question - How to center objects on top of each other
    The simplest way is to model them in place.
    Start with the main "box"
    For the next "box", create a new sketch on the face of the first one, and draw a rectangle. Dimension the rectangle relative to the edges of the first "box". When centered, extrude it to the correct height.
    Repeat.
    To round the corners, use the Filet command from the Modify menu.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2018
    I think I MIGHT have been successfulish.
    Attached Thumbnails Attached Thumbnails Screen Shot 2018-12-10 at 12.06.05 AM.png
    Jul 2019
    I don't know much about the adobe Photoshop but recently, I created marketing brochures for the essay writing Service Company and I simply modeled them in plan and use the main box.
  1. Newby Question - overlapping objects in RDCAM v8
    By demsley in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 02-03-2017, 05:53 PM
  2. sorry.. stupid question
    By newguy1985 in forum DIY CNC Router Table Machines
    Last Post: 07-01-2012, 03:48 AM
  3. may be a stupid question but......
    By kaighn80 in forum Welding Brazing Soldering Sealing
    Last Post: 03-30-2012, 02:59 AM
  4. This might be a very stupid question.
    By phacer in forum Fanuc
    Last Post: 10-27-2010, 01:25 PM
  5. Stupid Question
    By CNCRob in forum Community Club House
    Last Post: 09-04-2005, 07:42 PM
