599,432 active members*
2,797 visitors online*
Results 1 to 10 of 10
    Mar 2017
    1390
    support.planet-cnc.com update
    We are making new and better support system. Old system that we had was out of date and was not functioning like it should.
    We are making new one. Until it is ready we will give support on forum and on email. There is also a lot of information here: https://cnc.zone/
    Aug 2023
    6
    Re: support.planet-cnc.com update
    can you please upload an searchable pdf archive or a archiv webpage whith alle the blogposts? there is a lot of documentation missing at the new wiki. thank you in advance
    Mar 2017
    1390
    Most of information on old site was obsolete and no longer relevant. If you have something specific in mind let me know.
    Quote Originally Posted by mark0815 View Post
    This please a master pdf would be great.
    Mar 2017
    1390
    CNC.ZONE support portal/knowledge base is now the main source of documentation for TNG software and controllers.
    https://cnc.zone/kb/tutorials/tutorials
    Dec 2008
    51
    There a way to download the contents as .pdf files?
    Mar 2017
    1390
    If you have PDF printer then you can print to PDF.
    I have mk3/4 controller and its license oki and I’m trying to connect arduino mega with the controller but not direct connection i used the usb serial with pc ( the mk3/4 connected to pc with usb and same to arduino a usb with pc and on specific com port like com5) and i uploaded arduino code like serial setup and writing or reading data if there’s available as any normal serial code and i added expr.txt file in my profile folder with the code to read the data or sending through serial i saw in the wiki functions about serial communication .. but nothing being communicated by each other .. so i need a practical solution recently working to have serial communication between arduino and the mk3/4 and thanks in advance
    For shopping the product from https://planet-cnc.com, i cannot contact with buyer, i think you can update your proct to amazone or aliexpress...it is easy to buy with confidence!
    Mar 2017
    1390
    I tried multiple times respond to your emails, but your email server is blocking our messages.
    You can PM any questions here or your can try different email client.
  1. Replies: 1
    Last Post: 03-07-2021, 11:42 PM
  2. Replies: 4
    Last Post: 09-23-2019, 09:59 PM
  3. Replies: 1
    Last Post: 08-05-2019, 03:06 PM
  4. Planet CNC
    By yar20 in forum PlanetCNC
    Last Post: 04-26-2018, 05:31 PM
  5. GM215 Firmware Version Check/Update Support
    By interflexo in forum Gecko Drives
    Last Post: 01-28-2016, 10:09 AM
