585,992 active members*
5,878 visitors online*
    SV 1 ALARM ON FANUC 5 CONTROLS
    Hello All,
    I am currently facing an issue running my Mazak 2L Dynaturn Lathe with Fanuc 5 Controls. Fanuc has rebuilt the Servo motor and technicians have looked at this machine twice. The SV 1 alarm keeps going off when the machine moves in Negative X in Rapid mode. All other axis's work fine. Can you reprogram this type of machine to run in a slower mode other than Rapid? The machine works fine in Dry Run and Jog. Has anyone ever run parts in Dry Run instead of Rapid? Or has anyone had a similar issue with a machine like this.
    Thanks for any help.
    Elliott
    Aug 2019
    145
    Re: SV 1 ALARM ON FANUC 5 CONTROLS
    If you are certain the machine is mechanically ok (thrust bearings good, gibs adjusted correctly) I suspect a drive. I'm thinking that vintage used a forward and reverse bank of transistors/thyristors so one direction can be ok while the other is weak or bad (bad would typically be a constant alarm).
    Does the axis drive show any alarm LED's when the alarm trips? If you have 2 identical drives have you swapped them?
    And a note on Dry Run. Aside from being a constant rate vs a programed rate, I have seen where some OEM's bypass things like waiting for SAR (at speed) while it is active.
  1. Help with GE Fanuc Series 21 Controls
    By smokediver576 in forum EMCO Lathe
    Last Post: 06-12-2016, 10:19 PM
  2. Replies: 1
    Last Post: 12-30-2013, 07:05 AM
  3. fanuc g73 ot controls
    By Fire_Fly666 in forum Fanuc
    Last Post: 07-16-2010, 09:52 AM
  4. alarm 86 fanuc controls
    By machineman66 in forum Daewoo/Doosan
    Last Post: 06-12-2010, 12:32 PM
  5. fanuc controls
    By gabedrummin in forum Fanuc
    Last Post: 10-23-2008, 02:33 AM
