530,019 active members*
3,211 visitors online*
Results 1 to 6 of 6
    Switch between ESS and Internet
    Hi All
    I have just built a cnc router table and I am using Mach3 and ESS. Also on my computer I have Fusion 360 (free) which I am currently learning.
    The problem I have is that my ethernet adapter is configured to talk to the ESS but, as you know Fusion 360 requires the internet to operate.
    If I unplug the ESS and plug in the internet to use Fusion 360, the network adapter does not allow connection with the internet as it is configured to communicate with the ESS.
    I can re-config the adapter each time I use Fusion then run the Warp9 ESS config again but it is time consuming. i am sure there is an easier way.
    I don’t intend running fusion 360 or any other web programs while using Mach3.
    My question is, can I set up 1 network adapter for ESS and a separate network adapter for the internet so I can switch between the two.
    Any help on this problem would be greatly appreciated.
    Regards
    John
    Perth, Western Australia
    Mar 2003
    35138
    Re: Switch between ESS and Internet
    Yes, I use two adapters on my PC with a UC300ETH.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Nov 2012
    959
    You should be able to use a single Ethernet adapter and a switch/router. UC300ETH can be connected through a switch, right? It does not need a direct connection to the computer?
    Thanks very much for your help. I received a couple of replies about
    The UC300ETH so I will investigate that.
    Regards John
    - - - Updated - - -
    Quote Originally Posted by CitizenOfDreams View Post
    Regards John
    Mar 2003
    35138
    Yes, you can use a switch, but I prefer as second adapter. It's a bit easier to get working, and only about $15.
    And a dedicated adapter should potentially perform better if there's a lot of network traffic, I would think??
    Gerry
    Nov 2012
    959
    I don't think the traffic in a home network would cause any problems. Unlike the old school "repeaters" and "hubs", a modern switch routes network packets straight to their destination without clogging the rest of the network. The manual does not mention any potential problems either, it says the UC300ETH can be connected either directly to the computer or through a switch.
  1. Lan without internet
    By Karl_T in forum CamSoft Products
    Last Post: 06-28-2008, 01:48 PM
  2. Quoting a job through the internet
    By ricotututi in forum General MetalWork Discussion
    Last Post: 01-22-2007, 08:39 AM
  3. Internet Cad Files ?
    By Ken_Shea in forum Uncategorised CAM Discussion
    Last Post: 07-20-2006, 07:44 PM
  4. Internet Connection?
    By CNCadmin in forum Community Club House
    Last Post: 08-07-2003, 01:08 AM
