586,011 active members*
5,085 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > switching spindles and VFDs
Results 1 to 4 of 4
    Dec 2017
    18
    I am currently running my spindle through a VFD. If I get another spindle, different brand but same specs, is it just plug and play, or is there anything I need to change or look at?
    Jan 2005
    15362
    Re: switching spindles and VFDs
    Quote Originally Posted by turosan View Post
    If all the spec's are the same and the VFD Drive was setup correct to start with, then there would be nothing to change
    Just make sure that the spindle is correctly Grounded as some are not and this has to be corrected under the spindle Plug
    Mactec54
    Dec 2017
    18
    Thanks, I thought that might be the case, but wasn't sure. How do you tell if a spindle is correctly grounded?
    Jan 2005
    15362
    You do a simple continuity test between the 4th Pin in the Spindle plug and to the spindle body
    Mactec54
  1. IP66 VFDs
    By DavidWilliams in forum Education - Teachers and Students Hangout
    Last Post: 04-11-2019, 08:49 AM
  2. Chines Spindles and VFDs
    By Garysb in forum CNC Machine Related Electronics
    Last Post: 01-26-2016, 05:13 AM
  3. Any reasonably priced (cheap) spindles other than the chinese spindles?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 11-05-2014, 11:16 PM
  4. new to VFDs a few questions
    By integerspin in forum Phase Converters
    Last Post: 06-02-2010, 11:52 PM
  5. Spindles de alta qualidade.High quality spindles.
    By Newtron in forum News Announcements
    Last Post: 09-21-2009, 08:33 PM
