592,217 active members*
5,093 visitors online*
    Apr 2015
    5
    Lightbulb SYSTEM ALARM 945 SERIAL SPINDLE (1CH) ALARM
    this alarm appeared after sign in some parameters, i want to know if that was caused of them parameters or really the problem is about that alarm than reffers to problem of communication about spindle
    Aug 2024
    Re: SYSTEM ALARM 945 SERIAL SPINDLE (1CH) ALARM
    Hola buen día, como estas?. Has logrado resolver tu falla? Me sucedió exactamente lo mismo, y la maquina no me deja hacer nada. Tengo un control fanuc o-m instalado en un torno cnc.
    Sep 2024
    9
    Check logic board of spindle drive or connections between logic and power section. Clean the drive and connectors. Check parameyers with data sheet.
  1. Replies: 4
    Last Post: 05-03-2019, 08:58 PM
  2. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  3. Hitatchi Seiki ht 30g 2213 spindle speed 0 alarm and 2246 cutting spindle alarm
    By nixwake2snow in forum CNC Machine Related Electronics
    Last Post: 05-07-2014, 05:24 PM
  4. Alarm 408 Spindle Serial Link Start Fault
    By boricuajdm in forum Fanuc
    Last Post: 04-23-2007, 06:26 PM
  5. Alarm 408 Spindle Serial Link Start Fault
    Last Post: 04-21-2007, 05:19 PM
