529,919 active members*
2,209 visitors online*
Results 1 to 1 of 1
    Oct 2020
    System key not working
    Hi everyone
    I need to change a parameter in fanuc Oi- mate TD but the system hard key not working. MDI mode and emergency already are activated.
    Thank you
    Dec 2009
    632
    Re: System key not working
    take the parameters out,change the one you need and send them back to controller
    Oct 2020
    Thanks... unfortunately for outputing parameters system key is needed.
    Apr 2012
    43
    Maybe the MTB has it masked so it does not display.
    Keep relay?
    Try G10 L52 parameter replacement - look it up in operators manual.
