556,800 active members*
2,376 visitors online*
    Jun 2010
    8
    T.Align switch
    Amada turret punches have diferent switches on a control board (in our case named VIP-11) which handle some output status. Particularly there is one switch called T.Align which turns off the hydraulic pump. Amada advises to leave it on the OFF position. The ON position means that the pump will be turned OFF if the Tool change switch is turned to ON (and viceversa).
    What are the possible drawbacks of ignoring Amada´s advice and leave the T.Align switch on the ON position ? Having the pump working while changing the tools or loading a program to the CNC does not look like it is helping too much. Besides the noise of the pump is quite annoying.
    Jan 2012
    3
    Hi
    Alignment of stations usually take more time than setting up a tool. So you should use the tool align key when you are doing so.
    In case you want to turn hydraulic unit off while setting up a tool.
    1-You are preventing oil cooling process in off time.
    2-And specially in some models that the hydraulic motor is not starting by star-delta method, the shock of every stop-start is higher than you think!
    Simply as Amada advised keep ToolAlign key at off position .
    Norin1373@yahoo.com
    Good luck,
    M.R. Norin
    Jun 2010
    8
    Re: T.Align switch
    Quote Originally Posted by norin1373 View Post
    Hi
    Norin1373@yahoo.com
    Good luck,
    M.R. Norin
    Thanks for your comments.
    So, basically there are no safety issues involved, right ?
    We were actually thinking that pump on was desirable to keep oil warm enough, not to cool it. But either way, it keeps the heat exchanger busy :-)
    Pump motor power is rated 18.5 kw. So having a 24 hp motor running while loading a program to the CNC looks "weird". So basically you leave the machine working the whole shift ?
    Regards
  1. Replies: 0
    Last Post: 09-21-2015, 05:14 AM
  2. Help Align me
    By logger in forum Cincinnati CNC
    Last Post: 04-15-2011, 08:10 PM
  3. 3d Align
    By coykiesaol in forum Uncategorised CAD Discussion
    Last Post: 11-30-2010, 08:15 AM
  4. Align Honing or Align Boring ?
    By jonbanquer in forum General MetalWork Discussion
    Last Post: 11-09-2008, 04:33 PM
