585,996 active members*
4,544 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Takisawa TC-1 Fanuc 0-TC PMC parameters
Results 1 to 6 of 6
    Sep 2021
    6
    Good evening all, first time on here.
    I have a 1993 TC-1 that has had its parameters deleted. I have all the parameters that were punched out, however the PMC parameters 900-939 weren't recorded. If anyone has a copy it would be much appreciated.
    Regards
    Brad.
    Apr 2009
    1379
    Re: Takisawa TC-1 Fanuc 0-TC PMC parameters
    parameters 900-939 are options, The PMC parameters are called DIAGNOSTICS (parameters 300 on).
    Sep 2021
    6
    Thanks for your response. Sorry, my mistake. In the print out i have there is a gap between 899 and 940. So i have the Parameters excluding the 900-939, also I don't have the diagnostics settings.
    Sep 2021
    6
    I have managed to source some parameters/diagnostics for this machine. The issue i have now is that the ones I received appear to be for an 8 tool turret, however I have a 12 tool turret. Any idea which parameter/diagnostic number this may be?
    Dec 2009
    953
    try with diagnose 440,450,455 to set up the 12 tools
    Oct 2020
    Thank you zavateandu.
    I have found out that on this machine it is D435.7.
    Once the machine is confirmed running ok, i'll look at posting an updated list for the PAR and DGN.
  1. Replies: 3
    Last Post: 10-22-2020, 09:20 PM
  2. Takisawa TS-30 parameters for Fanuc 10T
    By madispilt in forum Fanuc
    Last Post: 10-06-2015, 12:39 PM
  3. Fanuc 3T parameters! (Takisawa TC 2)
    By cncdigital in forum Fanuc
    Last Post: 10-29-2010, 08:53 PM
  4. Lost parameters for Takisawa fanuc 3t
    By rrbird76 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-08-2009, 10:05 PM
  5. Need Parameters TAKISAWA TC1 FANUC
    By alexfanuc in forum Mach Lathe
    Last Post: 10-23-2009, 04:14 AM
