592,217 active members*
5,040 visitors online*
Results 1 to 5 of 5
    Takisawa TC-1 Help please
    I have a TC-1 that has recently been moved to a new location and now has a “Not Ready” fault. I have checked the e-stops and hard limit switches which are all ok however I only have 24v to the 2 +’ve limit switches.
    I have traced these back to the relay board on the door but the lose where they go (wiring diagram has been lost) however I have no relays active. I have checked these and do have 24v to relay CRRDY but it is not energised, relay has been changed and confirmed working. Any suggestions please
    Dec 2009
    1003
    Re: Takisawa TC-1 Help please
    did the signal X21.4 is 1 in diagnostic screen?
    The x21.4 in diagnostic is 0
    Dec 2009
    1003
    that means you are in emergency still and you need to check the safety circuit
    The x21.4 must be 1 if the 24v DC that comes from all the EMG buttons and the limit switches from hard over travel
    X21.4=0 EMERGENCY MODE ON
    The 24v signal from EMG is a series circuit and contains all these switches.
    If any of these siwtches do not have 24v dc on it when measure,the X21.4 will be 0
    Good luck
    Found the issues, had lost a load of the parameter’s. Once I reloaded these we were all good again
  1. Takisawa TS 15
    By Doctorie in forum Turning Machines
    Last Post: 10-29-2020, 12:30 PM
  2. TAKISAWA TC-2
    By panki in forum Machinery Manuals / Brochures
    Last Post: 03-23-2019, 02:01 AM
  3. Takisawa TS-20
    By Petkov in forum Machinery Manuals / Brochures
    Last Post: 12-11-2012, 01:17 PM
  4. Takisawa TS-15
    By directindustria in forum CNC Machining Centers
    Last Post: 05-13-2011, 12:26 PM
  5. Takisawa
    By Nickyjr in forum Canadian Club House
    Last Post: 03-18-2008, 10:17 PM
