531,941 active members*
2,715 visitors online*
Results 1 to 4 of 4
    Dec 2009
    451
    Temperature Calibraation Tower
    Does anyone here know of a pre-written G-Code file written to correspond to one of the "Temperature-Calibration" models that are available? I know that the models themselves can be downloaded for free and setup to print these tests in some of the slicer softwares available; and I also know that there is free slicer sofware available for download but, my question remains, is there an available download of pre-written G-Code that corresponds to one or more of these Temperature Calibration models?
    The slicer software I'm using is FlashPrint and if it does have the capability of setting up one of these calibration prints, I haven't been able to figure out how to do it. It would be so much easier to just be able to download a copy of a testing 3D print file made specifically for this application. I've just started looking for such a file. If any of you know where I can find it please let me know. Thanks in advance.
    MetalShavings
    Jun 2012
    162
    Re: Temperature Calibraation Tower
    Just insert this gcode at intervals (10 to 15 layers). Change the temperature for each entry.
    M190 S128 ; set bed temperature
    M104 S250 ; set temperature
    Dec 2009
    451
    elfrench:
    Thanks for taking the time to post your reply. I know how to edit the G-Code on my CNC mill but I don't know how to go about doing that with the slicer software that is native to the 3D printer I recently took delivery of. From what I can gather, the recent version of this "FlashPrint" slicer software no longer allows for editing the G-Code. I wasn't even able to access the G-Code that was generated just to take a look at it. I went ahead and saved the code you listed in your post in case I ever figure out how to edit this G-Code. It may come in handy if I ever decide to try yet another brand of filament. It seems that each differing filament has quirks of its' own that need to be figured out.
    Since I didn't know how to do the edit thing I had to tackle this obstacle the hard way. I printed out individual sections of the "Temperature-Calibration" model each at different extruder temps and then when I found the temperature I was looking for I then did the same with the bed temperature. It was a long drawn out process but I finally got my printer printing out decent prints.
    Thanks again for your input.
    MetalShavings
    Oct 2020
    Quote Originally Posted by MetalShavings View Post
    elfrench:
    MetalShavings
    In this case, it is better to call specialists who will help solve your problem.
  1. Eiffle Tower
    By flamineclipse in forum General MetalWork Discussion
    Last Post: 12-17-2013, 08:06 PM
  2. Eiffle Tower
    Last Post: 12-17-2013, 02:26 AM
  3. Signal Tower with G540
    By Cruz74 in forum Gecko Drives
    Last Post: 01-06-2013, 11:47 PM
  4. Help with robot-tower design
    By cnczoner in forum Mechanical Calculations/Engineering Design
    Last Post: 11-23-2008, 03:26 AM
