Hey, I recently built a machine for a customer.
This is a 3d router for furniture processing. The working area 2100x3000 mm's, base made of 150x250x8 profile, machined bases, Hiwin 35 linear guides, Atlanta HPR Module3 helical gears, drives through leadschine servo, longitudinal axis 2 kw, x and z 0.75 kw plus planetary gears, HSD spindle 9kw ATC, tool magazine for 8 pcs - maltanese gearbox, csmio ip-s control unit, counterbalance actuators for z axis, magazine pushback actuator, pins for fixing the material on the table, dust extraction, Becker 5.5 kw pump, some desktop for a mach3. A lot of protection in case of a collision, 6-section pressure table.
So, to not talk too much, I'm presenting pictures and some movies.
https://youtu.be/2HmWvgddi64
https://youtu.be/Kb4Y3wQ4-kg
