531,630 active members*
3,641 visitors online*
Results 1 to 8 of 8
    Mar 2008
    364
    the best steel type
    hello everyone,
    I am trying to make some tooling and seeing if some one can help me to choose the best kind of steel .
    I would like it to be very strong, I am also thinking of heat treating to make it hard, that way it will last a long time, this will be use for punch and dies.
    so far these are some steel types that I can think of (1018,1144,4140,and A36 ) if any one has a better idea I would greatly appreciated .
    Thank you
    Jan 2005
    11650
    Re: the best steel type
    Quote Originally Posted by cob View Post
    hello everyone,
    Thank you
    Would depend on what you want to use the punches for and what size, 4140 is the only one in your list that you can heat treat, the others can be case hardened but this as I said would depend on what you want to punch through the 1018 and the A36 is mild steel, this is not normally used for punch and dies
    Mactec54
    Aug 2009
    758
    ...quick answer is Tool Steel type
    https://en.wikipedia.org/wiki/Tool_steel
    Dec 2013
    4536
    A2 would be my first choice for punches and dies. Depending on the shape, you might be better to buy ready made punches & dies from Dayton Progress. https://www.daytonlamina.com/punch-die They'll make any shape you want for reasonable prices and a very quick turnaround time. I have buying from them for at least 40 years. Then all you need to do is make the punch & die holders, normally made from 4140 or 4150.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2008
    364
    thank you for the replies,
    can 4140 also be case harden?
    also do you guys have a good source where to buy some 3.5 O.D by 1.0 thick round blanks ?
    thank you
    Aug 2009
    758
    thank you
    ...the information highway your welcome.
    where abouts you at in usa?
    DJ
    Mar 2008
    364
    San Jose , California
    Dec 2013
    4536
    Yes, 4140 can be case hardened.
    Maybe try Metal Werx
    or https://www.mcmaster.com/steel
    or https://www.onlinemetals.com/
    Jim Dawson
    Sandy, Oregon, USA
  1. 3 Ton titling type steel scrap induction melting furnace
    By lyheater in forum Casting Metals
    Last Post: 11-01-2018, 09:28 AM
  2. How to determine type hardness of steel part
    By smokediver576 in forum Tormach Personal CNC Mill
    Last Post: 08-22-2016, 03:14 PM
  3. Type of Steel for Conical Spring Washers in CNC Drawbar
    By barchdesigns in forum Metallurgy
    Last Post: 11-15-2013, 04:39 PM
  4. what size/type steel?
    By 472viper in forum General MetalWork Discussion
    Last Post: 04-04-2008, 05:34 AM
  5. What type of steel for linear shafts can I machine?
    By cbcnc in forum DIY CNC Router Table Machines
    Last Post: 04-14-2004, 06:57 AM
